head work -- TC
PostPost by: el-saturn » Sat Jul 20, 2013 9:26 am
hi there all of you elanites. just figured you'd like to see the head i bought (ebay UK) a couple of weeks ago.
the welding as such was really good BUT nobody ever "cleaned" up - I did and am curious to see what you fellas have to say - it's nice work if you ever been in involved in pattern (model) making - so here U go: and greetings from the sunny alps sandy j
ELANhead.jpg and
PostPost by: billwill » Sat Jul 20, 2013 12:11 pm
Which parts of it were repaired?
PostPost by: el-saturn » Sat Jul 20, 2013 5:07 pm
the entire "carb faces" (carb mounting surfaces) all hand made Bill: i added an original casted or unwelded
version - i personally think it?s not all that shameful - or is it? cheers sandy
elanheaddetail.jpg and
PostPost by: john.p.clegg » Sat Jul 20, 2013 5:43 pm
Sandy
You've made a smashing job....how did you do it ?
John :wink:
PostPost by: billwill » Sat Jul 20, 2013 8:00 pm
I saw a crashed Lotus Elan in a breakers yard many years ago in which all 4 inlet pipes of the cylinder head had sheared across. Was that what had happened to yours? Or were you converting a Stromberg head to Weber style?
I was never sure whether they had sheared do to a full frontal crash or whether the breakers yard had broken them by trying to pick uo the car with a grab, front and rear. THe engine was pushed back, but the carbs had been stopped by the rear of the engine compartment.
At the time I did not realise that the head could be mended or I would have bought the engine, but as it was I only bought the Diff & propshaft.
PostPost by: el-saturn » Sat Jul 20, 2013 8:37 pm
hi bill - all of this 50 year old stuff has a (unknown) history and imagine that the intake broke of (or the top 1/3) somehow. then somebody "fabricated" by welding the top segment again. OR the threads were so worn that the owner had to add more meat: in any case this was the only acceptable solution I came up with. once all the rest is
mounted you won?t really notice it. if someone had this problem before he?ll probably know the magic which led to this practicable result. tomorrow we?ll have our local vintage meeting at the lake (from 10 to 1 pm) where i hope there aren?t too many morgans!!! have a nice evening sandy
PostPost by: el-saturn » Tue Jul 23, 2013 12:16 pm
i also posted a typical photo of our regular "scrapheap" (as my wife sees it) meeting: in the foreground
you see; as i told you ...... A Morgan! .............................but to our relief ol' 36/4982 - back ta woik!
sandy
