i lost the oil stick chain...
PostPost by: Pistacchio sprint 72 » Sat Feb 16, 2013 11:30 am
Darn, i noticed i lost the little chain that secure the oil stick. Do you know where i could get one of these?
Cooled down by CliveyBoy!
PostPost by: types26/36 » Sat Feb 16, 2013 11:38 am
Pistacchio sprint 72 wrote:Darn, i noticed i lost the little chain that secure the oil stick
Little chain ??? :?
types26/36
PostPost by: Pistacchio sprint 72 » Sat Feb 16, 2013 11:49 am
Yes, a little chain that linked my oil stick to the alternator. Should you have to check oil level you have to remove the chain first.
Well....not that i could ever loose the oil stick. :mrgreen:
PostPost by: pharriso » Sat Feb 16, 2013 12:22 pm
Cedric, I don't think that was fitted by the factory. A previous owner must have added it.
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: trw99 » Sat Feb 16, 2013 12:26 pm
Not original.
You should not have to worry about the oil dipstick ejecting itself - under normal conditions. There is no other involucre for the dipstick orifice.
PostPost by: pharriso » Sat Feb 16, 2013 12:34 pm
trw99 wrote:Not original.
Well, I learnt a new word today "In general, an involucre is a covering"
Phil Harrison
PostPost by: Pistacchio sprint 72 » Sat Feb 16, 2013 1:42 pm
Ok. I feel relieved...
PostPost by: oldelanman » Sat Feb 16, 2013 9:13 pm
Pistacchio sprint 72 wrote:Darn, i noticed i lost the little chain that secure the oil stick. Do you know where i could get one of these?
Just a thought.......was it a chain or a spring ? Some folks use a spring to stop the dip stick rattling.
S4 DHC
PostPost by: billwill » Sun Feb 17, 2013 3:09 pm
The Dip stick is composed of a loop of half-round steel rod. If there are any issues with it rattling or coming loose, it can by adjusted by pushing a screwdriver between the two halves outside the range of the tube and then pressing the lower halves back together with a vice.
It will then have a springy action with its natural diameter slightly wider than the tube and it will grip the inside of the tube.
To avoid any oil spitting from the top of the tube, you can slide a rubber sleeve from an old ignition lead (or spark coil lead) onto the dip stick and it will neatly cover the open end of the tube.
Users browsing this forum: No registered users and 46 guests
