large shim sizes
PostPost by: higgyuk » Mon Jan 28, 2013 7:05 pm
help! anyone comment on why i`m calculating 218thou sims to shim up VJ5 inlet cam ex is 143 is ok? me head? regards higgyuk
higgyuk
First Gear
First Gear
PostPost by: types26/36 » Mon Jan 28, 2013 7:18 pm
Thin after market cam follower fitted?
Cam follower worn on top?
Cam follower has had raised section (inside) machined down?
Valve tip has been ground down?
New valve seats too low in head?
Camshaft re-profiled?
Bent valve not seating?
types26/36
PostPost by: higgyuk » Mon Jan 28, 2013 7:24 pm
types26/36 wrote:Thin after market cam follower fitted?
kept followers with the cam shimmed in previos head at 88 thou so is head thanks will check your tips of valves and if valve too low would thick top steel followers help? higgy
higgyuk
First Gear
First Gear
PostPost by: elanman999 » Mon Jan 28, 2013 7:49 pm
Are the new valves shorter than the old ones?
elanman999
PostPost by: higgyuk » Mon Jan 28, 2013 8:02 pm
elanman999 wrote:Are the new valves shorter than the old ones?
i didnt valve the BV head but it appears overall better than average condition and not over skimmed
ive got some old followers i`ll see if i get better result and see if the crown inside is raised more even tophat ones (burton ) max out at 200thou i think hillman imp ones will fit HAVE SPRINT ONES AND CAN PUT THIS IN AND RECHECK IF THE RE-PROFILED CAM HAS BEEN UNDERCUT TOO MUCH CHEERS HIGGY
higgyuk
First Gear
First Gear
PostPost by: alexblack13 » Mon Jan 28, 2013 8:06 pm
Check all of the above.
Also.. Possible re-profiled cams? I fitted Burton re-profiled cams (a long LONG time ago) and had to use Cosworth .200" thick blanks to reset the clearances. The extra lift came from the re profilers removing metal from the shaft base diameter which was then made up with the thicker shims which = extra lift...
About 140 hp with a different exhaust. Can't remember who's.... That + 2 s130 went like the clappers. Wish I still had it!
Alex.... 8)
Alex Black.
Now Sprintless!!
alexblack13
PostPost by: higgyuk » Mon Jan 28, 2013 8:10 pm
alexblack13 wrote:Check all of the above.
Alex.... 8)
BLL14?
higgyuk
First Gear
First Gear
PostPost by: types26/36 » Mon Jan 28, 2013 8:48 pm
BLL14
BLL14 (Copy).JPG and
types26/36
PostPost by: alexblack13 » Mon Jan 28, 2013 9:09 pm
yes.. They were BLL 14's I had remembered and put the type on the post but then removed it again as I was unsure.
Memory is better than I thought!
I well remember having somewhat of a footer to get it all together.. It was fun from memory.
Al' ....
Alex Black.
Now Sprintless!!
alexblack13
PostPost by: higgyuk » Tue Jan 29, 2013 9:16 am
types26/36 wrote:BLL14
many thanks brian looks like this may apply to the vj5 `s higgy
higgyuk
First Gear
First Gear
PostPost by: 45bvtc » Tue Jan 29, 2013 10:28 am
I used Vegantune VJ5 camshafts with an Ed Winter polished and ported cylinder head in my 1971 Elan Sprint, brilliant!
The valve shim sizes (thickness) when new were:
Cyl._____Inlet _____Exhaust
#1 _____0.149"____0.206"
#2 _____0.148"____0.207"
#3 _____0.146"____0.195"
#4 _____0.146"____0.197"
So no worries for you!
Interestingly, the valve shim thickness changed little over 30k miles i.e., NO valve seat recession; a fantastic engine that would run on almost any fuel without pinking...
45bvtc
PostPost by: higgyuk » Tue Jan 29, 2013 11:41 am
45bvtc wrote:I used Vegantune VJ5 camshafts with an Ed Winter polished and ported cylinder head in my 1971 Elan Sprint, brilliant!
yes i agrree the Twin cam techniques profile TT36 is marvellous as these were in my S4 I DID 37K MILES THANKS du u remember tappet clearances? higgy
higgyuk
First Gear
First Gear
PostPost by: 45bvtc » Tue Jan 29, 2013 1:28 pm
I do indeed remeber the valve clearances:
SHIMS (again)
Cylinder____Inlet_________Exhaust
1._________0.149"_______0.206"
2._________0.148"_______0.207"
3._________0.146"_______0.195"
4._________0.146"_______0.197"
Valve clearance check:
1._________0.005"_______0.009"
2._________0.006"_______0.010"
3._________0.005"_______0.010"
4._________0.006"_______0.010"
And this engine remains running perfectly...
45bvtc
PostPost by: higgyuk » Tue Jan 29, 2013 2:10 pm
[quote="45bvtc"]I do indeed remeber the valve clearances:
SHIMS (again)
And this engine remains running perfectly...[/sounds good have built 2/3 tuned pre-crossflows, one 1600 1/2 race xflow -but the TC rules! higgy quote]
higgyuk
First Gear
First Gear
PostPost by: higgyuk » Tue Jan 29, 2013 7:41 pm
[quote="higgyuk"][quote="45bvtc"]I do indeed remeber the valve clearances:
buckets are STD 210 thou
inlet cam profile or should i say re-profiling has ground away the heels nearly to the shaft-requiring a lot more shim-could have been LONG stem inlet valves in the other head or the valve seats were cut deeper.
i still have to check the timing of this cam to make sure its the 35/85 i.e the INLET!the EX 79/41 seems to have not to have been ground as much --were getting there. higgy
higgyuk
First Gear
First Gear
Next
