engine camshaft broke
PostPost by: roshanjohny » Mon Nov 26, 2012 11:12 am
Hey am roshan, my car camshaft broke while on a steep slope and I cranked to start. .
wat is the reason???
roshanjohny
New-tral
PostPost by: types26/36 » Mon Nov 26, 2012 12:40 pm
Your post is a little difficult to decipher.
As you have posted in the "MODS" section I think more detail is required, we dont even know if it is a Twin Cam engine :?
You will have to give more information on the hows/when/where/mods/symptoms etc.etc.
types26/36
PostPost by: rgh0 » Tue Nov 27, 2012 10:14 am
looks like a robot post perhaps???
PostPost by: roshanjohny » Tue Nov 27, 2012 10:26 am
How?? - vehicle got off while in slope and was not starting. I had to crank it while vehicle was going down the slope in reverse condition
Symptoms- A sound from the engine side
roshanjohny
New-tral
PostPost by: rgh0 » Tue Nov 27, 2012 10:56 am
yeah looks like a bot to me
PostPost by: RogerFrench » Tue Nov 27, 2012 4:07 pm
While trundling backward down a slope, and startling the going motor, the giggling pin will interfere with the johnson rod and spill out all the blinker fluid.
RogerFrench
PostPost by: JJDraper » Tue Nov 27, 2012 6:25 pm
Give us a clue as to your location or original language. The meaning of your text is unclear and sounds like the result of automatic or word-for-word translation. Post in your original language if possible - someone on the forum may understand.
From what you have given, you could be confusing camshaft with crankshaft. Sounds like you tried to 'bump-start' it in reverse gear. Possible crankshaft bolt shear?? Unlikely, but need more accurate info!
Jeremy
PostPost by: holywood3645 » Tue Nov 27, 2012 6:29 pm
Great explanation Roger. I had exactly the same problem with my car. That would be the first place he should start looking, then report back.
James
PostPost by: CBUEB1771 » Sat Dec 01, 2012 2:24 pm
RogerFrench wrote:spill out all the blinker fluid.
That is the nasty part, most governments have pretty stiff fines these days for illegal discharge of blinker fluid.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
CBUEB1771
Users browsing this forum: joe7 and 45 guests
