5 minute oil filter change!!!!!!
PostPost by: carrierdave » Mon Aug 27, 2012 8:36 pm
I changed my oil pump to the screw on cartridge type some time ago and just recently looked to change the oil.
After about an hour messing around trying to turn the canister to get it off, I ended up using the old tried and trusted method ? I hammered a screw driver through it and then used that to twist the canister off.
So my question ? to those with the screw on canister oil filters ? What?s the best tool to remove the filter and can it be used from above or below the car?
Dave
carrierdave
PostPost by: hartley hare » Mon Aug 27, 2012 9:04 pm
smear of oil on o ring,
and hand tight only..
:wink:
hartley hare
PostPost by: john.p.clegg » Mon Aug 27, 2012 9:25 pm
Dave
Hard to describe but a three fingered ratchet type thingy that fits my half inch square drive,used from below,tightens on the sides of the filter........something like this.....
http://www.ebay.co.uk/itm/3-LEG-2-WAY-O ... 2ca&_uhb=1
John :wink:
PostPost by: carrierdave » Mon Aug 27, 2012 9:51 pm
Hi John - That looks ideal. I had a tool which is a bit like an oversized pipe grip, however that just creased/dented the oil filter.
I always use oil or grease on the o ring but for some reason the location and position of the oil filter makes it harder to remove.
At just a fiver its certainly worth giving it a go.
carrierdave
PostPost by: prezoom » Mon Aug 27, 2012 10:21 pm
Almost all of the oil filters I have on my cars, have the bottom stamped in a pattern that can use a very large stamped socket type wrench. Over the years, I have accumulated several different sizes from peanut sized to large. The medium sized one seems to fit the spin on filter for the Elan. I use a stubby 3/8" ratchet wrench, or with an extension if needed. No collapsing of the filter or poking holes to remove.
Rob Walker
26-4889
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
prezoom
PostPost by: Harvey » Mon Aug 27, 2012 11:21 pm
Some years ago I purchased a filter removal wrench from Griots Garage (www.griotsgarage.com). A recent catalog shows they still sell it for $12.99. As the Brits say, "It works a treat." The adjustable wrench grabs the filter securely allowing you to easily loosen it enough so you can spin it off by hand.
Jackson, CA
Harvey
PostPost by: reb53 » Tue Aug 28, 2012 6:22 am
I've got one that's very similar to the one described by John.
Makes things so much easier than the old "hammer a screwdriver through it" method.
Also, not nearly as messy...
Ralph.
reb53
PostPost by: peterako » Tue Aug 28, 2012 7:04 am
I use a variation of John's.
Works a treat, saves knuckles and keeps language clean.
Peter
'73 +2S 130/5
peterako
PostPost by: Chancer » Tue Aug 28, 2012 8:09 am
I have made, bought and used many types over the years including chain and strap wrenches before finaly finding the best tool to date, the one referred to above:
http://www.ebay.co.uk/itm/3-LEG-2-WAY-O ... 2ca&_uhb=1.
My car has an old fashioned cartridge filter with a thin plastic filter casing and its always a real bugger to remove even when hand tightened the time before, this tool removes it without damaging it which surprised me.
I have seen the solid tubular octagon drive socket types and they are certainly superior but you need thye right one for each vehicle whereas the above one has fitted all so far.
Chancer
PostPost by: carrierdave » Tue Aug 28, 2012 10:37 am
Thanks for all your comments. I too am sold on the three leg wrench device - it looks ideal to use from under the car and because it locates at three points I think there is less likelihood of the canister collapsing as you try and remove it.
I don?t tend to change the oil every year because of the issues with getting the filter off but hopefully with this tool I will retain the skin on my knuckles; cut down on the foul language and say to the wife with confidence ? ?I?ll just be 5 minutes?. Well maybe not the last one as there is always just one more job to do!!
carrierdave
PostPost by: Chancer » Tue Aug 28, 2012 11:21 am
My 72 Elan has an oilpump with a cartridge filter within a thickwall casing removed by unscrewing a hexagon fitting, arent they all like that or have they gradually been converted to canister oil filters?
Is that type of oil pump and filter still available, mine hasnt been changed in 30 odd years!!!
Chancer
PostPost by: john.p.clegg » Tue Aug 28, 2012 11:42 am
Chancer
I think it's about time you changed your filter.....
John :wink:
PostPost by: RogerFrench » Tue Aug 28, 2012 2:43 pm
I've used one of the strap-type wrenches with 1/2" square drive for yonks. Works very well.
Like http://www.amazon.com/Advanced-Design-ATD-5208-Filter-Wrenches/dp/B000OUZBTQ/ref=sr_1_3?ie=UTF8&qid=1346165053&sr=8-3&keywords=filter+strap+wrench.
Cheap as Chips, very effective.
RogerFrench
PostPost by: Galwaylotus » Tue Aug 28, 2012 5:48 pm
RogerFrench wrote:I've used one of the strap-type wrenches with 1/2" square drive for yonks. Works very well.
Ditto. :D
'67 S3 SE FHC
Galwaylotus
PostPost by: Chancer » Tue Aug 28, 2012 6:40 pm
john.p.clegg wrote:Chancer
John :wink:
Nah!!!
It gets run through with flushing oil once a decade the rest of the time the engine doesnt turn.
Chancer
Next
