Engine rebuild nearly ready. What cc does +40 give?
PostPost by: SAKO » Tue May 22, 2012 11:56 am
Just a quick question gents.
I'm awaiting return of my bottom end, which is currently being rebored +40 using Omega pistons from PM.
Out of sheer curiosity what cc will this now give?
Burton used to have a list showing the increase in cc in relation to overbore sizes, but it doesn't appear to be there anymore, and I'm too thick to work it out. :roll:
Cheers.
Sako.
1972 Lotus Elan +2S 130/5
SAKO
First Gear
First Gear
PostPost by: robertverhey » Tue May 22, 2012 12:56 pm
Hi, 40 thou is 1mm so do your bore x stroke based on adding 1mm to the bore diameter.
If I remember my high school maths, the formula is 2 times pi times radius (half your new diameter) times stroke
Won't be much different from standard I don't think
Robert
robertverhey
PostPost by: RogerFrench » Tue May 22, 2012 2:15 pm
Capacity is Pi*Rsquared*stroke*no. of cylinders.
Your 40 thou overbore gives 1595 cc.
RogerFrench
PostPost by: elj221c » Tue May 22, 2012 2:38 pm
According to my book of notes I give you:-
3.25" +00 82.550mm 1558cc
3.26" +10 +.254mm 82.804 1567
3.27" +20 +.508 mm 83.058 1577
3.28" +30 +.762mm 83.312 1586
3.29" +40 +1.16mm 83.566 1596
83.50 1594
85.0 1651
86.0 1690
Roy
'65 S2
elj221c
PostPost by: SAKO » Tue May 22, 2012 3:54 pm
A whole 38cc! Well that's enough to power a good lawnmower. I hope my spine can cope with the extra G- force. :)
Cheers Guys.
Sako.
SAKO
First Gear
First Gear
PostPost by: robertverhey » Tue May 22, 2012 10:57 pm
Oops yes 2 x PI x radius is circumference....with apologies to my maths teacher, turning over in his grave no doubt
robertverhey
Users browsing this forum: pptom and 32 guests
