who sells these swirl pots? (with temp sensor hole)
PostPost by: gordont » Thu Mar 15, 2012 4:39 am
These seem like a good idea with the sensor hole for the fan switch.
I missed one of these for sale on ebay, any one know who sells them? Tried TTR and Kelsport but neither have them.
swirlpot.jpg and
swirlpot1.jpg and
Gordon
26/5416
gordont
PostPost by: vernon.taylor » Thu Mar 15, 2012 7:14 am
Salut Gordon
I'm sure you've seen the other one on eBay:
header.JPG and
... but at a hefty ?160. I imagine Andy Wiltshire (?) could make one, too.
All the others I've seen are vertical types which complicates plumbing.
If you don't need the swirl function, then there's always Cliveboy's/Ford's thermostat housing, and I have seen a sort of in-line radiator cap attached to a straight tube that could be inserted in-line, but I haven't been able to find it again.
If you find something not too expensive and not too bothersome to fit, let me know!
Vernon
vernon.taylor
PostPost by: rcraven » Thu Mar 15, 2012 11:01 am
vernon.taylor wrote:a sort of in-line radiator cap attached to a straight tube that could be inserted in-line, but I haven't been able to find it again.
Did you mean one of these? http://www.cbsonline.co.uk/product/In-Line_Radiator_Filler_Neck_38mm_INF38
Robert
rcraven
PostPost by: Andy Wiltshire » Thu Mar 15, 2012 6:17 pm
Hello Gordon,
I was looking at making these shortly, and yes, the threaded boss for a thermostat makes good sense.
In respect of price I was hoping to keep them close to the ?100 figure.
I would need the thread size and type for the thermostat used.
Andy Wiltshire
Axminster Specialist Panels
andywiltshire.com
Andy Wiltshire
First Gear
First Gear
PostPost by: Witofthestaircase » Sat Mar 31, 2012 3:04 pm
Gordon I can not only sell you one of these, I can sell you the actual one in your photograph. Having offered it up its apparent that it is devised to suit a radiator that has been moved a little further into the nose as there isn't quite sufficient space between thermostat housing and standard wide rad in its standard location to fit the swirlpot/tank between. I'd ideally get my ?117.25 back..
Let me know before I stick it back on ebay!
Russell
Witofthestaircase
First Gear
First Gear
PostPost by: Famous Frank » Fri Apr 06, 2012 1:45 am
Russell, I sent you a PM. If you get a moment, can you respond? Many thanks.
Famous Frank
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
Famous Frank
PostPost by: Witofthestaircase » Fri Apr 06, 2012 11:52 am
I'm sorry Frank I can't see your pm Would you mind just emailing me? [email protected] Thank you
Witofthestaircase
First Gear
First Gear
PostPost by: Famous Frank » Sun Apr 08, 2012 8:26 pm
Russell, could you please email me at:
[email protected]
The email address you provided doesn't seem to be working. Thank you, Frank.
Famous Frank
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
Famous Frank
PostPost by: Andy Wiltshire » Thu Aug 02, 2012 7:05 am
Please see the business and vendors section for the Elan water tanks that I now make.
Andy Wiltshire
http://www.andywiltshire.com
Lotus Elan water tank ASP resized.jpg and
Andy Wiltshire
First Gear
First Gear
Users browsing this forum: No registered users and 44 guests
