Oil catch tank
Salut
Looks like a nice little unit:
http://www.ebay.co.uk/itm/small-oil-cat ... 2700wt_949
Anyone recommend a different unit?
Vernon
Vernon
vernon.taylor - Fourth Gear
decided to go simple....I replaced the 10cm rubber hose from head to inlet manifold with a piece about a metre long which I looped under the carburettors. this means that the gunk has plenty of time to condense before it reaches the manifold. I have an idea that eventually I'll need to raise the loop to let the crap run back into the sump & will probably do this before next oil change . I've been running this setup for about 1000 miles so far and there is just enough crap in the hoises for an audible bubbling noise as gasses pass through it
RichC - Fourth Gear
vernon.taylor wrote:Salut
Save ?25 and do it my way:
It was in place all last summer with the plastic jar sitting out of the way at the bottom corner of the radiator.
In a previous lifetime I used small metal containers filled with course wire wool. I had thought to do this with the plastic jar but, over my usual 500 miles summer travel there was only about three drops of residual oil, so concluded it was not worth while trying to be technically correct by using wire wool. However, I shall keep my eye on it again this year.
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
bcmc33 - Coveted Fifth Gear
Hi Vernon, how about:
http://www.caterhamparts.co.uk/product. ... roduct=268
all the bits you need and light weight plus it doesn't look too out of place
regards
regards
_________________
1969 ELAN PLUS 2S
1998 CATERHAM 7 SUPERSPORT
1969 ELAN PLUS 2S
- elan_fan
elan_fan wrote:Hi Vernon, how about:
regards
Basically just a washer bottle
If you put a rubber bung in the drain hole of the fibreglass under the cluch/brake masters and routed the rubber pipe to there, you would have an even lighter catch 'tank', which you could occasionally take the bung out of & drain to a tray.
But would an open top be dangerous as it might LIGHT UP in a different way
Henry
1967 S3 FHC
A joke a day helps you work, rest, and play.
1967 S3 FHC
- Henry VIIII
Forgive me but which oil are we trying to catch?
Pete.
http://www.petetaylor.org.uk
Pete.
elansprint71 wrote:Forgive me but which oil are we trying to catch?
Oil vapour from the vent at the top rear of the head.
Henry
1967 S3 FHC
1967 S3 FHC
- Henry VIIII
Henry VIIII wrote:elansprint71 wrote:Forgive me but which oil are we trying to catch?
Much obliged. I use the original Lotus (and NASA) solution, i.e. vent to atmos.
Shirley this is one of the least-productive sources of escaping oil on an Elan? I've seen more oil on an Italian's comb.
What does one do with it when one "catches" it, anyway?
Pete.
Pete.
- TT sells a taylormade tank that drops into the space in the engine bay behind the inner wheelarch......very neat, no drilling and fixing etc. ......Not for free though, but I guess there are no copyrights attached....
Dag
Dag
Dag-Henning - Third Gear
Salut les gars
Nice, cheap, but not so pretty solutions.
It appears that the eBay unit I linked is just a compressed air/pneumatic filter! And when you call it that you can get them for less than a tenner.
I saw some Mustang boys doing just that. One appeared to have stuck a bit of wire-wool scouring pad into the container as a baffle. Might just do that myself.
Vernon
Vernon
Salut
My homemade oil catch can now has a few hundred kliks and seems to be doing the job, i.e. there's a small amount of gunk in the bottom:
As mentioned in the thread it's a compressed air water filter from eBay. The hosetails are from a company called Tmex - they have all sizes in nylon and brass - good address. So nylon tube from a right angle head grommet to the filter and then reinforced nylon tube back to the carburettor air box.
IMPORTANT: if you try this at home REMOVE THE FILTER ELEMENT. I didn't, and once it was clogged with oil the cam cover washers started to weep oil. Also think about the location - mine is maybe neat but it's a little awkward to unscrew the clear plastic recepticle.
Vernon
Vernon
