Gasket set - Washers?
PostPost by: AHM » Tue Feb 14, 2012 9:44 am
Hi All,
I have several bottom end gasket sets. All seem to have parts in them that I have no idea where they go!
a thin section 'O'ring
small thick ally washer
larger copper crush washer
Also the top end set that I have has a 2 inch diameter cork washer/seal
Any ideas?
Simon
AHM
PostPost by: AussieJohn » Tue Feb 14, 2012 9:56 am
The copper one is probably for the sump plug.
AussieJohn
PostPost by: alan.barker » Tue Feb 14, 2012 10:03 am
thin section "o" ring for dizzy :wink:
Alan B
PostPost by: oldelanman » Tue Feb 14, 2012 10:20 am
AHM wrote:2 inch diameter cork washer/seal
Oil filler cap ?
S4 DHC
PostPost by: elanman999 » Tue Feb 14, 2012 10:41 am
Simon,
The thick alloy washer is for the chain tension pivot bolt.
elanman999
PostPost by: alan.barker » Tue Feb 14, 2012 11:25 am
Simon, game set and match :mrgreen: :mrgreen:
Alan B
PostPost by: AHM » Tue Feb 14, 2012 10:29 pm
AussieJohn wrote:The copper one is probably for the sump plug.
could be -I have 2 sizes from different kits will check
alan.barker wrote:thin section "o" ring for dizzy :wink:
Alan B
Good - I need one!
oldelanman wrote:Oil filler cap ?
right size - not sure I'll use it.
elanman999 wrote:The thick alloy washer is for the chain tension pivot bolt.
That's what I thought, but it is too small.
I will post a picture.
Simon
AHM
PostPost by: ardee_selby » Tue Feb 14, 2012 10:44 pm
That's what I thought, but it is too small. I will post a picture. Thanks,
Simon
This it?
ardee_selby
PostPost by: Robbie693 » Wed Feb 15, 2012 2:00 am
Oil filler cap ?
As an aside to this, does anyone know where one can get cork gaskets for the filler cap? The rubber ones available from the usual suspects don't seem to work for me, seeming to be a bit too thin, I was wondering if the cork ones were a bit thicker?
Sorry for the slight hi-jack
Robbie
Robbie693
PostPost by: oldelanman » Wed Feb 15, 2012 3:48 pm
Robbie693 wrote:
Oil filler cap ?
Robbie
Perhaps Simon can tell you where his came from......
S4 DHC
PostPost by: AHM » Fri Feb 17, 2012 9:24 am
Unfortunately not - I have a gasket set from the PO - I think it came from Christopher Neil in about 1985. The rubber on on my filler cap is US so I've used the cork one (one less thing to sort out!)
Simon
AHM
PostPost by: garyeanderson » Sat Feb 18, 2012 12:55 am
the 2 inch cork gasket is for the fuel pump bowl
Gary
fuel punp bowl gasket.JPG and
garyeanderson
PostPost by: Robbie693 » Sat Feb 18, 2012 2:07 am
piss-ant wrote:the 2 inch cork gasket is for the fuel pump bowl
Gary
Ah! Ok, so a fuel pump gasket is what I need. Thanks Gary, and thanks Simon for letting me know.
Robbie
Robbie693
PostPost by: oldelanman » Sat Feb 18, 2012 8:08 am
It could be but the seal that comes with the AC service kit is rubber not cork.
AC fuel pump 034.jpg and
S4 DHC
PostPost by: garyeanderson » Sat Feb 18, 2012 2:05 pm
I have picked out cork before out of at least one (from my bad memory), maybe dpo owner installed but fuel pump is not in the top end set. I am only guessing on this, I looked for a part number in the master parts list. I could not find the one for the cap so who knows. I have been wrong before and I will be again and that is not of much concern to me. I just state what I see or remember.
Gary
garyeanderson
Next
