Alloy blocks
PostPost by: reb53 » Tue Jan 24, 2012 8:26 pm
Interested to hear some of the collective wisdom on this block, and its price.( GBP = NZ$2 ).
More out of curiosity really, and a desire to put a little bit of knowledge away for the future.
http://www.trademe.co.nz/a.aspx?id=441293648
Ralph.
reb53
PostPost by: garyeanderson » Tue Jan 24, 2012 9:23 pm
Its alloy, I don't think its Cosworth, Jennings or Kam. The grade 8 cap screws look out of place to me.
Gary
7500nzd alloy block.jpg and
garyeanderson
PostPost by: Elan45 » Thu Jan 26, 2012 2:50 pm
Is it an old block or something currently produced. More than the grade 8 bolts, I find the non-square main caps out of place. I also like to use studs and nuts anywhere I can on alloy castings. I also like studs for main caps, head to block and rocker gear (non-Elan).
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
Elan45
PostPost by: CBUEB1771 » Thu Jan 26, 2012 3:04 pm
I don't care for the way it has been machined, lots of passes on a CNC mill with small diameter end mills or fly cutters. It looks like it was done on a machine without enough X and Y travel to clean up the ends of the block without repositioning on the table.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
CBUEB1771
PostPost by: elj221c » Thu Jan 26, 2012 3:29 pm
CBUEB1771 wrote:I don't care for the way it has been machined, lots of passes on a CNC mill with small diameter end mills or fly cutters. It looks like it was done on a machine without enough X and Y travel to clean up the ends of the block without repositioning on the table.
This is the way it should look..........
http://www.davidgathercole.co.uk/engines.html
Roy
'65 S2
elj221c
PostPost by: reb53 » Fri Jan 27, 2012 5:03 am
Thanks for the comments so far and thanks for the link Roy.
Now, an FVC in an Elan, that sounds an interesting project....
Ralph.
reb53
PostPost by: blackandgold » Sat Jan 28, 2012 8:10 am
I saw a similar block for sale on trademe last year might be the same one or somebody is manufacturing them in NZ
Not sure how the asking price compares with this one from the US but you would have to add transport and loacal taxes for one shipped from overseas
http://www.bdaengines.com/Prod1Engine.htm#Alloy Cylinder Block
1973 +2 S130 with BDA
blackandgold
PostPost by: sevenhead » Sun Jan 29, 2012 9:08 am
These are cast in the UK.
sevenhead
New-tral
