S1 vacuum actuators
PostPost by: rodlittle » Fri Jan 20, 2012 1:45 pm
Does anyone know if both the left and right vac actuators on an S1 are the same?
Or do they have different mountings?
rod
rodlittle
PostPost by: garyeanderson » Fri Jan 20, 2012 2:20 pm
photos are probably here on this forum somewhere but I'm not searching any more today.
headlamp vacuum canisters1.JPG and
headlamp vacuum canisters.JPG and
garyeanderson
PostPost by: rodlittle » Fri Jan 20, 2012 2:28 pm
thanks Gary I was wondering about the bottom mounting, I can always block off the spare vac input
rod
rodlittle
PostPost by: toomspj » Fri Jan 20, 2012 4:23 pm
Rod - you can use them either side if you block off spare outlet. The only thing is that the outlets do end up pointing in an inconvenient direction.
Paul
Turning money into noise!
toomspj
PostPost by: Elan45 » Sat Jan 21, 2012 1:57 pm
I just reinstalled the actuators on my S3. All are pre- fail-safe, so the same according to the parts book.
I remember there being another 1/4" mount that goes horizontally through the inner wing (fender) which is another handed aspect of the vac pod, besides the vac line locations and number of them.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
Elan45
PostPost by: rodlittle » Tue Jan 24, 2012 2:29 pm
Thanks guys
There was one on ebay but I was just beaten and matty havent got any for at least another month so I guess Ill just have to use my spare LH one and change it when I can find the RH one
rod
rodlittle
