Lotus Elan
Starter motor mounting ring
PostPost by: 106500 » Sat Dec 17, 2005 8:30 pm
Having just replaced the starter motor on my S4 Elan, I noticed that the mounting ring behind the motor is broken in two (not sure how this happened - the starter motor was securely mounted).
Paul Matty stocks a ring but which is integral to the rest of the gear box to engine interface. On my car, the starter motor ring is separate to this (presumably to facilitate easy replacement - avoiding engine removal).
Obviously I'd like to replace just the mounting ring. Are these still available? Advice would be appreciated.
106500
PostPost by: john.p.clegg » Sun Dec 18, 2005 7:22 am
Are you talking about the thin plate between the bellhousing and block(comes in two pieces,upper and lower) if so there is/was one on EBAY recently.
John :wink:
P.S.
Or if you have a hacksaw your one piece one can be modified.....
PostPost by: john.p.clegg » Sun Dec 18, 2005 7:27 am
Found it
Is it ebay 4597978077 ?
John :wink:
PostPost by: 106500 » Sun Dec 18, 2005 9:00 am
Thanks - Thats the one. I note from the image on EBAY that the segment by the starter motor is split - it maybe that mines not necessarily damaged after all?
Can these still be obtained from suppliers? (Paul Matty just sells a one piece assembly).
106500
PostPost by: john.p.clegg » Sun Dec 18, 2005 10:12 am
I think that this is a weak spot as it's not supposed to be like that,but a spot of weld and a quick grind and should be as good as new
John :wink:
Users browsing this forum: 2cams70 and 35 guests
