engine
hi has anyone got any photos of the best way of lifting a twincam engine (ie lifting points)or straps
- gary eastham
gerrym wrote:Same as previous reply except raise the rear wheels of the of the car 1 foot higher than the front. Makes the angle of the dangle much easier.
regards
Gerry
Now that's simple & clever; I like that
Great photo Brian, it tells all
Beware of the Illuminati
GrUmPyBoDgEr wrote:gerrym wrote:Same as previous reply except raise the rear wheels of the of the car 1 foot higher than the front. Makes the angle of the dangle much easier.
regards
Gerry
I like that idea, too. Just dissapointed that I didn't think of it first.
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
bcmc33 - Coveted Fifth Gear
bcmc33 wrote:GrUmPyBoDgEr wrote:gerrym wrote:Same as previous reply except raise the rear wheels of the of the car 1 foot higher than the front. Makes the angle of the dangle much easier.
regards
Gerry
Aye a canny Scott is our Gerry
LOL....
Looking great Brian!... Running yet?
Alex...
Alex...
Alex Black.
Now Sprintless!!
Now Sprintless!!
Brian,
Thanks for the photo, its really useful as I have to do this for the first time next week (I hope).
What are you using as a anchor point on the the exhaust side of the engine?
Now for the naive question, is it alright to put that much weight on the aluminum ports of the head?
Thx
Thx
1970 Martini Green +2S,
- bg109685
'Aye a canny Scott is our Gerry'
Except that he's Australian!!
- mikealdren
- mikealdren
- mikealdren
OK ok...We heard you the 1st time!!
AB.
AB.
Alex Black.
Now Sprintless!!
Now Sprintless!!
mikealdren wrote:'Aye a canny Scott is our Gerry'
1. So why's he called Gerry and not Bruce?
2. So why's he called Gerry and not Bruce?
3. So why's he called Gerry and not Bruce?
Same thing- bloody foreigner.
Also raising the back end allows a bit more "swing room" for the tail-housing.
I put the sling under the thermostat housing on the exhaust side.
Pete.
http://www.petetaylor.org.uk
Pete.
bg109685 wrote:What are you using as a anchor point on the the exhaust side of the engine?
There's no strength issues lifting the complete assembly by the head, and the lift point on the exhaust side is under the thermostat housing.
The picture shows the complete engine and gearbox being removed from the car. This is not my normal practice as I usually remove the head first, but in this case the engine had done less that 1k miles and I didn't want to ruin an expensive Cometic head gasket.
It is also my normal practice installing the engine and gearbox to do so without the cylinder head in place - then I sling from the engine mounts.
I do this because I always seem to be messing with the exhaust when the engine is out, and its a lot more convenient to put the manifolds in from the top which cannot be done with the head in place.
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
Users browsing this forum: phil1800 and 37 guests
