Millers Semi Synthetic....
Is anyone running Millers Semi Synthetic oil in their engines? Is it recommended?
MArk
MArk
Hi Mark,
I am running Millers Classic Sport 20W/50 which is a semi-synthetic. I find it excellent. Good oil pressure even when engine very hot (though I do have an oil cooler) and not too expensive. Oil usage about 600 miles per pint (but very little leakage) on newly rebuilt engine (4000 miles ago).
Nothing to complain about at all except perhaps availability. My local motor factor orders it in specially for me.
Roy
Roy
Roy Gillett - Second Gear
rocket wrote:I have used millers for 4 years in my twinc no problems at all,touch wood! Terry i changed from mineral,simply drained ,new filter and refilled with semi syn all has been well.
Ian
Excellent I'll put it on the UK list for the trailer for Half term in October!
Terry
- terryp
mark030358 wrote:Is anyone running Millers Semi Synthetic oil in their engines? Is it recommended?
Mark,
#1 recommendation from Matty when I bought me car.
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
bcmc33 - Coveted Fifth Gear
I am also using using Millers CSS 20w60 semi-synthetic in my +2. I have an oil temp gauge fitted and the oil temp rockets upwards when the engine is being used hard, such as autobahns and mountain passes. The temp gauge scale goes to 140 DegC and the needle goes above that when the engine is being used hard, so I chose an oil that can take the punishment.
Jeremy
Jeremy
JJDraper - Fourth Gear
JJDraper wrote:I am also using using Millers CSS 20w60 semi-synthetic in my +2. I have an oil temp gauge fitted and the oil temp rockets upwards when the engine is being used hard, such as autobahns and mountain passes. The temp gauge scale goes to 140 DegC and the needle goes above that when the engine is being used hard, so I chose an oil that can take the punishment.
Jeremy
Hi Jeremy,
A temperature gauge is a handy thing to fit but I'm a bit alarmed about the 140?C readings you've noted.
140?C is not critical but it is extremely high.
From experience I would expect temperatures of that magnitude only at sustained very high engine revs.
Engine oil temperature is strongly related to engine speed & high temperatures should be anticipated on high speed Autobahn runs.
Are you sure that the temperature also rises as high on mountain passes?
When hill climbing the regular gear changes usually keep the oil temperature down but not necessarily the coolant temperature.
If you are certain that the gauge is reading accurately I think that you should be investigating the reason for such high temperatures.
I'm punching in the dark here but I suspect that you may be overfilling your engine with oil?
If the level of oil in the oil pan/sump is too high the crankshaft & con-rod big ends will make contact with the oil (punching/thrashing) which imparts energy = heat into the oil which can cause a dramatic rise in temperature.
Apologies if I've done the Granny sucking Eggs thing
Beware of the Illuminati
