engine back plate fowling on Slave cylinder
PostPost by: JR44 » Wed Mar 16, 2011 9:59 am
Hi does anybody have a close picture of a slave cylinder as i have a problem with fitting mine due to it fowling on the engine back plate not sure if there i should bend the tab on the back plate
JR44
PostPost by: bcmc33 » Wed Mar 16, 2011 11:07 am
JR44 wrote:Hi does anybody have a close picture of a slave cylinder as i have a problem with fitting mine due to it fowling on the engine back plate not sure if there i should bend the tab on the back plate
Where's your picture to show what the problem is?
Brian Clarke
(1972 Sprint 5 EFI)
bcmc33
PostPost by: oldelanman » Wed Mar 16, 2011 2:44 pm
Hi John,
The tab on the plate stops the slave cylinder rotating so it does touch but you should not need to bend it to get the cylinder in. If I recall correctly the plate is a snug fit on the dowels which locate the bellhousing on the engine so it should not be possible to misalign it - perhaps a dowel is missing ?
Clutch slave 003.jpg and
S4 DHC
PostPost by: Shiny_kit » Wed Mar 16, 2011 6:29 pm
Hi. Replaced mine recently and had to take a file to the back of the slave, it would not quite fit as you found out. Just a few passes with a file did the trick - bad casting I assumed.
Andy.
1968 Plus Two
2020 Royal Enfield Continental GT 650
Shiny_kit
PostPost by: JR44 » Thu Mar 17, 2011 11:04 am
Great thanks guys thats exactly what i was looking for I`ll give that a bash tonight
JR44
