Chain tensioner
PostPost by: kstrutt11 » Sat Mar 12, 2011 8:18 pm
According to the picture I have in the manual there should be a washer between the front of the timing chain tensioner pivot and the cylinder head, mine did not have one when I stripped it down, can anyone tell me how thick it should be?
Kevin
kstrutt11
PostPost by: rgh0 » Sat Mar 12, 2011 11:05 pm
The washer is Aluminium orginally and about 1mm thick. Its a seal washer like on a sump plug.
I normally use a medium strength locking compound on the pivot pin which also seals the thread as well as ensuring it does not come loose
regards
