Igniton swith connections
PostPost by: cdraper » Mon Dec 13, 2010 1:09 pm
Ignition switch connections.
Have rewired an Elan +2 and find no feed to the coil - suspect I have some crossed wires on the ignition switch. Strangely the workshop manual does not show which wre should go to which termeinal on the back of the igniton switch. Can anybody help?
cdraper
PostPost by: gerrym » Mon Dec 13, 2010 5:13 pm
Switch in dash or (later cars) part of locking column?
G
PS, I can only help with the locking column type
gerrym
PostPost by: cdraper » Mon Dec 13, 2010 8:16 pm
Switch is in dash - but it is the saame switch as used on the locking version. Help much appricated!
cdraper
PostPost by: billwill » Mon Dec 13, 2010 11:07 pm
That'll teach you to make an accurate list the next time you dismantle your dash :lol: 8)
I usually work it out again from first principles, and I can't lay hands on the last diagram I made, but the S4 Wiring diagram which is a 'photo' on this site somewhere shows:
1. Bat NU (brown blue)
2. Ign. White & it looks as this is the feed to the ignition coil via the loop in the tacho.
3. Start WR White Red the lead to activate the starter solenoid
4. ACC (accessories?) WP = White/Purple.
One of the terminals (I forget which) has TWO connector prongs on the same contact.
PostPost by: steve.thomas » Tue Dec 14, 2010 11:38 am
From my 72 S130 the wiring on the switch is as follows.
1. To solenoid to operate starter. 1 wire White/Red.
2. Live feed from battery and feed to fusebox for door lights etc. 2 wires Brown.
3. To Ignition, Coil. 2 wires White and Red (thin).
5. To Accessories, windows etc. 2 wires Yellow and Red (thick).
The numbers refer to what is actually stamped on the switch next to each terminal.
steve.thomas
PostPost by: billwill » Tue Dec 14, 2010 12:13 pm
Oh, Oh that is quite different....
The S4 Wiring diagram is drawn as if the numbers in my message above are what is marked in the switch..
So you have a problem.
I think you will need to do what I do, take the switch out and use a multimeter in continuity (low ohms mode)to identify which is the COMMON connector (that goes to the live feed from the battery, then it will be straight forward to identify the others.
Start by finding the START connector that will be the one that is only connected to ANY other connector when the key is hard over in the start position. Then Identify the Accessories connector, that will be the one only connected to anything when the switch is turned left (?)
PostPost by: rdssdi » Tue Dec 14, 2010 2:35 pm
My memory fades but I believe the ignition lead goes to the "theft deterrent" switch in the glove box before going to the coil.
If you can match your car to one of the several +2 workshop manual wiring diagrams it should be rather accurate.
Bob
rdssdi
