BDA/BDG reproduction blocks
Peter, I do believe there are at least two different ones. One carry the Ford logo, the other don't....Sometimes this is a requirement for scruteneering. I have no idea of the quality differences, but a guy like Geoff Richardsson, of G...R... Engineering ( check his website !)will be able to tell you. Furthermore, some come with nicaseal bores, others not, and Geoff will for sure be able to advice you what you should choose.....
Dag
Dag
Dag-Henning - Third Gear
Both the tall BDA/Formula Ford block and the shorter Twin Cam cylinder blocks are now available from Ford Motorsport. These are a direct replacement block in standard bore(81mm for the tall "uprated"block and 82.5mm for the Twink) and have many improvements like the main bearing saddle design, improved thrust washer configuration, contempoary casting accuracy as well as very thick cylinder walls for easy over size bores. Not cheap but the ultimate iron block for these engines and no more mucking around with tired old cylinder blocks needing a variety of expensive repairs. Should really drop the price of used blocks a lot.
- Jeff@Jae
- maybe you can get the BDG block from them as well ??
Dag
Dag
Jeff@Jae wrote:.............. and the shorter Twin Cam cylinder blocks are now available from Ford Motorsport. These are a direct replacement block in standard bore(81mm for the tall "uprated"block and 82.5mm for the Twink) ....................
Out of interest Jeff, how does one contact Ford Motorsport for further details?
SJ
Elfin Monocoque (Twin Cam)
[email protected]
[email protected]
SJ Lambert - Fourth Gear
elan-f15/ford-kent-engine-back-production-t19684.html
The above link is to a topic on the recently introduced Ford blocks. There is not a lot of info as of yet other than pricing and some general specs on the 2 different blocks.
Ken Anderson and I talked in late October about them and he was going to try to talk with Mose Knowland at the SEMA show earlier this month. I haven't heard from him since then so I guess I need to email him and see whats going on.
Gary
Gary
- I see that Cosworth promote their own original BDG alu block with logo....SAS engineering says they machine their BDG blocks from "original Cosworth castings" , so maybe there is only one casting for the 2l. alublock...... (???)- at least with Ford-logo...
Dag
Dag
SJ Lambert wrote:Out of interest Jeff, how does one contact Ford Motorsport for further details?
You can find Ford Racing dealers in the US at this link:
http://www.fordracingparts.com/wheretobuy/main.asp
I am not sure of the best contacts in the UK but this might help:
http://www.powertorque.co.uk/ptr_engines.html
Ford Racing dealers are plentiful in the US. I have a 1600 version on order from my local dealer, Forte's Parts Connection in Framingham, Massachusetts. These items are real and in stock. Forte's normally deals with US marketed V8s but they knew exactly what I was talking about when I walked through the door. I ordered on November 10th and should see it in two or three days. I could have gotten it faster if I wanted to pay freight but I opted to wait until Forte's had a large stock order coming in.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
Hi, In case interested, Woodcote Racing at Silverstone (Phil Barak) has a number of BDA spares for sale including an AX Block, BDA Head, Forged pistons, Camshafts and other BDA/BDG equipment. For details, please call Phil on 01237 858074.
- Woodcote Racing
I bought a 90mm 4 bolt main nickaseal Alloy Block from KAM Developments in the UK several years back
I think Gordon Parks at 'Blue Sky Racing' is the US agent now. It did not have a Ford Logo.
http://www.blueskyracing.com
James
James
holywood3645 - Fourth Gear
