Engine cutting out.
Bugger. I know that this will bring up A LOT of possible solutions, but here goes anyway: My +2S/130 is playing up a bit, driving along this morning, three times the engine cut out on me, but leaving it in gear it would then pick up again and carry on. Just once as I was in 2nd gear pulling into a small road did I have to restart, but then it started right away.
There doesn't seem to be any hesitation, it just dies. Could it have something to do with the +3-4 C degrees this morning ? As I've had it since this summer.
What's up?
big valve +2S/130 with twin40s and lumenition.
What's up?
- thor
Thor,
Does it cut out under certain conditions - if so which ones - or is it random?
If it's random it sounds like an electrical problem to me - check all of the connections in the ignition circuit including the spade terminals on the ignition switch as these can work loose (they did on mine..) plus those on the fuel pump. It may be fuel related, but I would have thought that you'd see some hesitation rather than it cutting out completely.
simon.mitchell - Second Gear
After I had rebuilt my s130 I had a similar problem with cutting out, yes it was electrical, and changing the coil cured it. Mind you that was the last thing I tried ! Plugs, leads, points, condensor, dix cap, rotor, solenoid, & coil last. It would start fine, run and then just die, spose the windings were shot (whatever they are). Foxed me for ages............jc
- john-c-elan+2
check your anti-theft switch fitted in the glovebox as well.
I had the same problem once and the switch was the problem
Robin
Robin
- bengalcharlie
Just to join in the last point.... Anti theft switch! I wondered what that was. How does it work? Does it just break the low tension circuit to prevent starting or what?
Simon
Simon
- phatmendus
I believe it swaps the ignition coil for the horn,so when some bugger tries to start it,it sounds off!
No,the recommendation is to strip out the switch and reconnect the wires permanently(I.E. bypass the switch)
