Cam Cover
PostPost by: andyhodg » Fri Aug 20, 2010 12:14 pm
Hi All
Has anyone had the gasket face on a cam cover skimmed to return it to a flat condition? Aftyer trying a cometic cam cover gasket I find that my cover is not flat enough to allow it to seal adequately. There is some distortion (about 15 - 20 thou) on the front edge of the cover.
If so any recomendations for a suitable machine shop?
Andy
andyhodg
PostPost by: GrUmPyBoDgEr » Fri Aug 20, 2010 1:29 pm
Should be a fairly straightforward job for any Machine shop with a Milling Machine with sufficient Table movement.
I'm planning to get a Cam Cover Casting done, but here in Germany.
Sometime there was mention of a Guy either in Coleshill or Shustoke who makes/machines posh Twincam bits.
Is the "Cometic" seal a multi-layer Steel type of Gasket that's been discussed on here in the past?
If so it would be interesting to hear other users comments on their experiences.
The Stud/Hole spacing for clamping the Cover to the Head are IMHO, to say the least marginal & I don't think they would provide the required, even clamping forces for a pressed steel Gasket.
I hope you'll post the results, as & when.
Beware of the Illuminati
GrUmPyBoDgEr
PostPost by: andyhodg » Fri Aug 20, 2010 1:56 pm
Yes it is the gasget that has been discussed previously. It consists of an aluminium backing sandwiched between two layers of rubber. The overall thicknes is less than 1mm so the rubber thickness is small and certainly not thick (or soft) enough to take up the 15 thou variation I have. (Sorry for the interchange of units but I am finding muyself increasingly ambidextrous in that area)
Andy
andyhodg
PostPost by: SADLOTUS » Fri Aug 20, 2010 2:02 pm
'I'm planning to get a Cam Cover Casting done, but here in Germany.'
Cool!, Standard older version?, Standard newer version? Big Valve? Holbay? Holbay ribbed with centre cover? Novamotor?
Sounds good, give us a clue!
SADLOTUS
PostPost by: GrUmPyBoDgEr » Fri Aug 20, 2010 2:11 pm
SADLOTUS wrote:'I'm planning to get a Cam Cover Casting done, but here in Germany.'
None of those!
Clue, you have seen it :lol:
GrUmPyBoDgEr
PostPost by: GrUmPyBoDgEr » Fri Aug 20, 2010 2:51 pm
andyhodg wrote:John
Andy
Ha, ha,
When I was studying I had to cope with FPS; MKS & ISO all within the same period; I think that's what made me the retard that I am.
I started off left handed & still am :lol: :lol: :lol:
I wish you the best of luck with the Gasket; let's hope you have some success.
Have a good Weekend
GrUmPyBoDgEr
PostPost by: paddy » Fri Aug 20, 2010 3:09 pm
D.J.Pelly wrote:Is the "Cometic" seal a multi-layer Steel type of Gasket that's been discussed on here in the past?
Here: elan-f15/cam-cover-gasket-again-t20572.html
For me, it works well, I have no leaks from the cover for the first time ever.
Don't forget that you always have the option of RTV only (no gasket) instead of machining the cover.
Paddy
1963 Elan S1
paddy
PostPost by: Greg Foster » Sat Aug 21, 2010 3:13 pm
I had my cam cover milled flat by a local machinist. The cover was warped a good 1/8". I also tried the Cometic Thin, reuseable cam cover gasket. Could not get it to stop leaking. Silicone would have done the trick but I went back to using cork. Also changed from using the rubber sealed cam nut gaskets to a fiber washer and haven't had any leaks around the bolts. Sometimes the "D" seals stick up above the sealing surface of the head too much, so I use a belt sander( holding the "D" seal flat against the belt by hand...not on the cyl. head) and remove enough of the flat to allow proper compression of the D seal and cam cover gasket. Reinstall adding a smear of silicone to the bottom of the D seal and letting it harden befor torquing the cam cover has eliminated any oil leaks from the cam cover....for a while......
Greg
'67 s3 SS
'72 +2 S130
Greg Foster
PostPost by: twincamman » Sat Aug 21, 2010 3:28 pm
geez guys while your adding some silicone to the D rubbers run a small bead around the cam cover -add the gasket -then set it gasket side down on a flat surface WITH A PHONE BOOK ON TOP ----goes as flat as my girl friends chest -----add a bit of oil to the head sealing surface and you can reuse the gasket time after time ----and it will not leak ----[ 10 torque pounds on the nuts only and use a washer please -----] ----ed
twincamman
PostPost by: GrUmPyBoDgEr » Tue Dec 21, 2010 9:47 am
None of those!
So now the job's done, all the sealing surfaces milled flat, stud holes drilled, painted & Monza filler cap fitted.
I'm pleased with it although my Photos don't really do it justice.
My thanks to the kind member who sold me the casting.
I think that most will agree that this is a very unusual Cam Cover. :wink:
Merry Christmas to all
Cam Cover6.jpg and
Cam Cover5.jpg and
GrUmPyBoDgEr
PostPost by: CBUEB1771 » Tue Dec 21, 2010 1:47 pm
Sir Pelly,
I thought for sure you were working up a cam cover with the BMW logo, but Cosworth is a nice touch.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
CBUEB1771
PostPost by: GrUmPyBoDgEr » Tue Dec 21, 2010 1:59 pm
CBUEB1771 wrote:Sir Pelly,
A Lotus Cam Cover with a BMW Logo, heavens forbid :shock:
Disclaimer:- I no longer have any connection with that company :D :D :D
The "Cosworth" idea was that of a respected poster on here; I saw it & begged him for one.
Aren't I the lucky one :wink:
just John Pelly Esq. :lol:
GrUmPyBoDgEr
PostPost by: bigvalvehead » Tue Dec 21, 2010 7:04 pm
Hi John
Really nice job.
Looks good enough to fit on a 26R or even a Shapecraft!!!!!!!!!!!!!!!!!!!!!!!!!
Happy Holidays everyone
dave
26-R-9
Shapecraft replica.
Dave Hughes
S2 26R
Elan DHC Sprint
bigvalvehead
PostPost by: GrUmPyBoDgEr » Tue Dec 21, 2010 9:13 pm
bigvalvehead wrote:Hi John
Really nice job.
dave
26-R-9
Shapecraft replica.
Oh you are awful; but I like you :lol:
That should give the Christmas festivities a kick start :wink:
GrUmPyBoDgEr
PostPost by: bcmc33 » Wed Dec 22, 2010 12:00 am
Apart from the pension, John. 8) 8)
Brian Clarke
(1972 Sprint 5 EFI)
bcmc33
Next
Users browsing this forum: No registered users and 51 guests
