Bad Night - Found Broken Manifold Stud
PostPost by: jonnyconcrete » Tue Jul 27, 2010 8:13 pm
Home from work, pleased to have received my synchrometer in the post...off to the garage...started the engine and left it to warm up whilst I was sorting my stuff out...air box off...noticed a spitting sound from over by servo...carefully felt around the manifold....erm....
Stuff it, felt the spitting and guessed it was a failed gasket. Engine off, I thought I'll just loosen the manifold bolts and check their condition...erm...
No7 stud was loose, so I thought...oh well easy fix, I'll just tighten it...after about 6 turns I'm thinking this isn't going to tighten!
Guess what, it never did!!
So I have a broken stud...any ideas/solutions?
Stuart
jonnyconcrete
PostPost by: twincamman » Tue Jul 27, 2010 8:53 pm
WELLL COUNTING FROM THE TOP FRONT OF THE ENGINE EXHAUST OR CARB SIDE NUMBER 7 IS AT THE TOP AND EASY TO GET AT ------SO --[I'm assuming the stud hole is stripped]--USE A HIELACOIL OR GO UP TO THE NEXT SIZE STUD --if the stud is broken in the hole careful tapping with a pointed object should remove the offending piece or drill and use an easy out -ed
twincamman
PostPost by: john.p.clegg » Tue Jul 27, 2010 9:04 pm
...are you sure it's the stud and not the nut that's stripped...
John :wink:
PostPost by: jonnyconcrete » Tue Jul 27, 2010 9:06 pm
Bonza...it's the nut...what size is it?
jonnyconcrete
PostPost by: types26/36 » Tue Jul 27, 2010 9:33 pm
jonnyconcrete wrote:Bonza...it's the nut...what size is it?
Stud threads into head 5/16 UNC .......Nut threads onto stud 5/16 UNF
types26/36
PostPost by: jonnyconcrete » Tue Jul 27, 2010 9:43 pm
Thank you Sir!
jonnyconcrete
PostPost by: alexblack13 » Wed Jul 28, 2010 10:01 pm
Remember to use the proper brass nuts bud. No nylocks. They will not be nylocks for long.. Good quality spring washers too..
I think I have a few spare brass nuts if you only need 1 or 2..
AB..
Alex Black.
Now Sprintless!!
alexblack13
PostPost by: billwill » Wed Jul 28, 2010 11:49 pm
I don't have washers at all on my exhaust manifold studs just the brass nuts. I don't recall ever having washers there.
PostPost by: 69S4 » Thu Jul 29, 2010 6:11 am
billwill wrote:I don't have washers at all on my exhaust manifold studs just the brass nuts. I don't recall ever having washers there.
Not "adding lightness" are you Bill?
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69S4
PostPost by: alexblack13 » Thu Jul 29, 2010 7:30 am
I use a good quality plated washer 1st against the manifold then a good spring washer, new every time, then a longer version (homemade) nut on a bit longer (again home made) stud. The nuts are 18mm long. And yes I know about the heat effect on the spring washers, but they do take a grip I can assure you.
But hey, what do I know! I'm only a humble mech' eng.
AB....
Alex Black.
Now Sprintless!!
alexblack13
PostPost by: GrUmPyBoDgEr » Thu Jul 29, 2010 11:04 am
alexblack13 wrote:I use a good quality plated washer 1st against the manifold then a good spring washer, new every time, then a longer version (homemade) nut on a bit longer (again home made) stud. The nuts are 18mm long. And yes I know about the heat effect on the spring washers, but they do take a grip I can assure you.
AB....
Colin Chapman:- "You're not taking all of those Washers for a ride on MY CAR!!!" :lol:
Errm! the reduction of Components in a Joint enhances the capability of that Joint.
Sorry, had to be said :roll:
Beware of the Illuminati
GrUmPyBoDgEr
PostPost by: alexblack13 » Thu Jul 29, 2010 12:17 pm
Who told you that load of bollocks? :shock: Slacknuts!!
& spring washers weigh F all.....
:lol: :lol: AB....
Alex Black.
Now Sprintless!!
alexblack13
PostPost by: Galwaylotus » Thu Jul 29, 2010 1:10 pm
alexblack13 wrote:Who told you that load of ballocks? :shock: Slacknuts!!
No need to get personal and start calling names, Alex! :lol: :lol: :lol:
'67 S3 SE FHC
Galwaylotus
PostPost by: alexblack13 » Thu Jul 29, 2010 1:35 pm
Sorry Shineyheed.. I should know better!
:lol: :lol: AB.. :wink:
Alex Black.
Now Sprintless!!
alexblack13
PostPost by: GrUmPyBoDgEr » Thu Jul 29, 2010 2:32 pm
alexblack13 wrote:Who told you that load of bollocks? :shock: Slacknuts!!
:lol: :lol: AB....
Tried searching for Washers on an Aero Engine Alex
The Weight thing was a "Chapman Quote", something he said to Graham Hill I believe.
I worked in Engine design for 45 Years, probably a bad habit I picked up, but I remember that Spring Washers were banished to the Scrap Heap before I was allowed to push a Pencil across the Paper.
Washers, yes, OK for protecting soft Materials & Load spreading where necessary, with a Brass Nut for example.
If they're available in UNF I'd recommend using Silver plated double Hex. Nimonic self locking Nuts for the Manifold. That's what I have on my Zetec in Metric & lucky enough to have enough for my Twincam in UNF. No Washers & "Tightnuts" (Even when only wearing a Kilt; gets cold here!) :wink:
GrUmPyBoDgEr
Next
