Engine stand
PostPost by: martinbrowning » Sun Jun 27, 2010 7:22 pm
Hi there,
I have recently purchased an engine stand to ease the rebuild of the engine from my S130. Miles Wilkins states in his book that the engine should be attached to a stand using the exhaust side mounting point. However, the mounting plate on my stand is too large and I was considering mounting the engine by using the engine/bellhousing connecting points.
Any thoughts please?
regards
Martin B
martinbrowning
PostPost by: alexblack13 » Sun Jun 27, 2010 7:57 pm
Never tried it Martin, but don't see why not providing its within balance etc.
Just dont drop it on your foot! :shock:
Alex.. 8)
Alex Black.
Now Sprintless!!
alexblack13
PostPost by: types26/36 » Sun Jun 27, 2010 8:05 pm
I've mounted them on exh side,inlet side and bell housing bolts, it will work but mounting it there makes it difficult to get to the flywheel,clutch, oil seal etc. the best is the exhaust side then you can get round everywhere,
Cant you modify your stand?
types26/36
PostPost by: neilsjuke » Sun Jun 27, 2010 9:35 pm
neilsjuke
PostPost by: paddy » Sun Jun 27, 2010 9:48 pm
neilsjuke wrote:http://www.flickr.com/photos/16638375@N03/sets/72157605202952079/
Neil
I guess this is the photo in particular:
http://farm3.static.flickr.com/2059/242 ... 63_o_d.jpg
Paddy
1963 Elan S1
paddy
PostPost by: neilsjuke » Mon Jun 28, 2010 7:38 am
All made out of the scrap bin was using engine mounting bolts to block now use head exhaust studs
My dummy layshaft is drilled and taped makes lining up with one pair of hand easy
So over the years I now have a range of brackets
Neil
neilsjuke
Users browsing this forum: No registered users and 49 guests
