Major componenet oil consumption
PostPost by: StoatWithToast » Wed Jun 09, 2010 9:21 am
Hey all,
Just looking for any info on how much oil cars get through for the engine, gearbox and diff.
Especially the box and diff.
I know the engine uses some because of the design but not sure how much, if any, should be used by the others (and how much I should panic).
Oh, and I did have a search around but couldn't find anything, but if you know of a thread I'll gladly read that instead.
Dave
'06 Elise SportsRacer 111R
'72 Sprint FHC (and staying that way) - 0479
'65 XI Replica
[And a Subaru, but I don't think that counts ;)]
StoatWithToast
PostPost by: rocket » Wed Jun 09, 2010 9:44 am
Hi Dave,
My plus 2 engine uses about a quarter of a litre max per 5,000 miles mainly due mainly to a couple of small drips here and there,never needed topping up tween yearly service,mileage being around 5,000 a year.Diff and gearbox dont use any and shouldnt unless leaking..
Ian.
rocket
PostPost by: StoatWithToast » Wed Jun 09, 2010 9:57 am
Thanks!
Looks like they are all leaking :(
The diff isn't too bad and has cleared up a bit with frequent use, but the gearbox is pretty bad. Seems like there could be a few reasons for this too having read the service books I have.
The engine is using more than that too, but it is mainly coming from the dip stick (not sealed) and the cam cover filler (seal is probably shot after nearly 40 years without being replaced. It does drip a little when stationary, but like the diff, not that much.
Starting to want to do a nut-and-bolt check, clean and replace on the car, but that will have to wait until the winter, assuming we have found somewhere for the XI to live by then :?
Dave
'65 XI Replica
StoatWithToast
PostPost by: rocket » Wed Jun 09, 2010 10:32 am
You probably know Dave that the dip stick leak is easy cure useing a spark plug rubber cap..
Ian.
rocket
PostPost by: StoatWithToast » Wed Jun 09, 2010 10:38 am
Ah ha! Nope, didn't know that, but will put it into practice this weekend!
Cheers!
Dave
'65 XI Replica
StoatWithToast
Users browsing this forum: No registered users and 44 guests
