Moving on from the Plug Cut
Just found this link to a David Vizard article from way back.
Hope it pastes okay:
http://www.niksula.cs.hut.fi/~mdobruck/ ... 0/dyno.htm
Seems as if we can all have our own dyno at home, as long as we've got a Colortune!
Seems a little 'hairy' to me.
Regards.
Regards.
- stuartgb100
Interesting article from a historic perspective. However modern technology has moved on a bit. You can now use a wide band lambda sensor with a logging terminal to do the same.
http://www.innovatemotorsports.com/
I have used one of excellent little devices to great effect in setting up the carbs on my S4. The engine now runs between 12.8 and 13.8 AFR under various conditions.
steveww - Coveted Fifth Gear
