Removed engine and 'box
PostPost by: dpchamp87 » Wed May 05, 2010 1:47 pm
So almost 37 years to the day after I bought my first Elan I finally took a motor out. Took it out together with the 'box and apart from having to lower the front of the car to allow the bellhousing to clear the engine mounts it was plain sailing. Some jobs on these cars are just a bitch due to either cost cutting or Lotus nonsense (eg doing anything to the clutch slave; getting the headers off; getting the lhs engine mount off) but it's out now and the next job is to keep gearbox oil in the gearbox.
It is a YES! moment when the bellhousing pops over the engine mounts.
David
1970 S4 with Sprint motor
dpchamp87
PostPost by: bill308 » Thu May 06, 2010 12:08 am
And it's an even bigger YES when it's put back in place ready to GO.
:D
Bill
bill308
PostPost by: billwill » Thu May 06, 2010 3:40 pm
However it is an Oh soddit moment when you discover the gearbox oil runs out of the back end, if you forgot to drain it beforehand.
As I recall.
:oops: :oops: :cry: :|
PostPost by: dpchamp87 » Thu May 06, 2010 8:49 pm
It certainly would be. Even after draining the oil I had a foot wide puddle on ground and it's still dripping out of the chassis spine. I wish someone would invent gear oil that smells like something good; cabernet for instance.
David
dpchamp87
PostPost by: pereirac » Fri May 07, 2010 1:50 am
I always figured that oil on the chassis stopped rust at least so it's not all bad :D
Carl
Carl
72 Elan Sprint
87 Excel SE
97 Alpina B10
http://www.lotuselan.co.uk
pereirac
PostPost by: hatman » Fri May 07, 2010 10:13 am
dpchamp87 wrote: I wish someone would invent gear oil that smells like something good; cabernet for instance.
You need Redline MTL you do. :wink:
hatman
PostPost by: alexblack13 » Sun May 09, 2010 9:33 pm
What! are you kidding! :shock: It smells worse IMHO... and its too fecking pricey to spill. But I managed it! I decided I would use a big syringe to fill my diff'. Great idea I thought. Filled the device and stuck the hose in the hole (as you do!) and pushed and pushed and pushed harder until... Sploosh.... the hose shot off the end of the syringe and I had (stinking & expensive) redline gear oil everywhere. What a feckin mess!! :? :?
Took ages to clean the mess up and I could have done without the hassle and it did stink to the high heavens!!
What is the answer for filling the diff in situ? Access panel in the boot or what? whats the best idea?
Alex B.... 8)
Alex Black.
Now Sprintless!!
alexblack13
PostPost by: bcmc33 » Sun May 09, 2010 11:02 pm
alexblack13 wrote:What is the answer for filling the diff in situ? Access panel in the boot or what? whats the best idea?
Diff Access Plate.JPG and
This is a 5" port hole from a dingy. If I'd given it more thought it could have been a 9" port which would give access to the hand brake tree.
Brian Clarke
(1972 Sprint 5 EFI)
bcmc33
PostPost by: 69S4 » Mon May 10, 2010 6:11 am
My answer was similar but smaller - a 2" blanking grommet. Remove the n/s rear wheel to get access to the filler plug and add oil down a pipe that goes through from the hole in the boot.
That dingy part does look like a good solution though.
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69S4
PostPost by: alexblack13 » Mon May 10, 2010 7:41 am
Yep. Going to take me a look at one of those or similar.. I have the ramp mind so getting under the car is not an issue.. :wink:
Thanks..
Alex B.... 8)
Alex Black.
Now Sprintless!!
alexblack13
PostPost by: alexblack13 » Mon May 10, 2010 7:43 am
Ment to ask how it works....
Doh!!
Alex... 8)
Alex Black.
Now Sprintless!!
alexblack13
PostPost by: ElliottN » Mon May 10, 2010 2:06 pm
I pump it in with a small hand pump.
Hand Pump.JPG and
Elliott - 70 S4 dhc
ElliottN
PostPost by: trw99 » Mon May 10, 2010 2:44 pm
alexblack13 wrote:Ment to ask how it works....
Doh!!
Alex... 8)
Alex
These are standard fittings in a lot of sailing boats and readily available in a variety of sizes and colour!
You would need to cut a hole the size of the outer ring and epoxy glue that in place. The hatch cover then engages in the ring and twists to form a waterproof seal. They probably weigh little more than the glass you have cut away.
PostPost by: alexblack13 » Mon May 10, 2010 8:26 pm
Result! I will go and have a look asap. That + that little hand pump sounds good to me..
Thanks all.
Alex B.... 8)
Alex Black.
Now Sprintless!!
alexblack13
PostPost by: twincamman » Tue May 11, 2010 6:49 pm
my motor and tranny just hit the floor at 12 noon to day for a new ring gear ----hope to have it back in by Sunday - :lol: --ed
twincamman
Next
Users browsing this forum: No registered users and 57 guests
