SILLY QUESTION
PostPost by: bcmc33 » Sun Mar 28, 2010 3:28 pm
Just about to assemble the sump to the block and found a nylon washer (20mm diameter x 13.25 mm bore x 2mm thick) in the gasket set. Where does this go?
Brian Clarke
(1972 Sprint 5 EFI)
bcmc33
PostPost by: oldelanman » Sun Mar 28, 2010 3:32 pm
Sump drain plug ??
S4 DHC
PostPost by: Jason1 » Sun Mar 28, 2010 5:15 pm
Sump plug washer sometimes nylon but mostly copper.
It could be though as I cannot think of another use for a nylon washer so you could be right??
Jason
Jason1
PostPost by: bcmc33 » Sun Mar 28, 2010 5:50 pm
I guess it is a sump plug washer - I had the answer all the time had I the intellegence to look.
My sump has a tapered 3/8" BSP sealing plug, but a cross flow sump I have for the tall block engine I plan to build has a straight hex head plug with a nylon washer.
:oops: I said it was a silly question :oops:
Brian Clarke
(1972 Sprint 5 EFI)
bcmc33
PostPost by: alexblack13 » Sun Mar 28, 2010 6:03 pm
Hi Guys,
Probably miles away here but could it be for use on the cam drive chain tensioner pivot bolt? The one that screws into the front of the timing chain cover/
Just a thought, If its not for the sump, which is normally copper.
Alex B.... 8)
Alex Black.
Now Sprintless!!
alexblack13
PostPost by: types26/36 » Sun Mar 28, 2010 6:20 pm
I'm sure Roger is correct.....sump plug, as it has always been supplied with all of the gasket sets I have bought and many of these sets were for the Xflow OHV engines.
types26/36
PostPost by: Robbie693 » Mon Mar 29, 2010 9:28 am
I bought a sump plug washer from Paul Matty a couple of years ago and it was Nylon
Robbie
Robbie693
PostPost by: Jason1 » Mon Mar 29, 2010 2:49 pm
Roger was right, pic on SJ Sportscars site.
SJ Sportscars.jpg and
Jason1
