breather tube between block and head
Kevin,
When new it is a fairly soft rubber and somewhat flexable. Over time and engine heat it gets hard and can loose its abillity to seal well. A new one can be flexed enough to install and I use a squirt of rtv sealer on both ends to seal. I let it sit overnight for the sealer to setup before starting engine.
memini55 - Third Gear
Hi Kevin,
I've done it too but it's a tight squeeze. Even when new the tubes are not that flexible and it requires a fair bit of effort to squeeze it in - my thumbs ached for a while afterwards! Suggest you tackle from the top, removing the carbs first.
Good luck
Robbie
Good luck
Robbie
I don't know if it's still available, but there was a pushrod tube repair kit for air-cooled VW. It's two tubes with gaskets and nut that allows you to split it, put it in and tighten enough to seal. Worked for me some 20 years ago.
Fred Talmadge - Third Gear
Kevin,
it's rubber and wiil squeeze in. Try using a bit of silicon sealant around the ends to stop any oil leaks
Carl
Carl
pereirac - Fourth Gear
