Jackshaft
PostPost by: bcmc33 » Tue Dec 29, 2009 5:36 pm
With my engine now in pieces I have the opportunity to do things.
As I don't use a mechanical fuel pump it seems reasonable that I should cut the jackshaft in half, plug the rear bearing oil hole and reassemble.
Is this as reasonable as I've said?
Brian Clarke
(1972 Sprint 5 EFI)
bcmc33
PostPost by: GrUmPyBoDgEr » Tue Dec 29, 2009 6:07 pm
Yes as easy as that Brian, in fact easier:-
Push out the rear Bearing Shell & replace with the Oil Hole rotated out of position = Blanked off.
You might also find someone with a Lathe who would Turn off the redundant Cam Lobes from the Jackshaft.
Not necessary but sort of "tidy"
Beware of the Illuminati
GrUmPyBoDgEr
PostPost by: Foxie » Tue Dec 29, 2009 7:40 pm
D.J.Pelly wrote:Yes as easy as that Brian, in fact easier:-
I did this. Cam lobes interfered with my stroker, so I made up a jig for the grinding wheel and removed 'em.
Will post photo when virus removed from my main PC
68 Elan +2, 70 Elan +2s
PostPost by: bcmc33 » Wed Dec 30, 2009 5:33 pm
Past the point of no return - jackshaft now cut in half. Must find something the right diameter to get the shell out.
I have to admit that the cam lobes bothered me regarding a balance issue. Four lobes now ground down. I was surprised how deep the chill went - too hard for turning.
Brian Clarke
(1972 Sprint 5 EFI)
bcmc33
PostPost by: Foxie » Thu Dec 31, 2009 12:13 am
bcmc33 wrote: Past the point of no return - jackshaft now cut in half. Must find something the right diameter to get the shell out.
My machine shop rotated the shell for me :)
PostPost by: bcmc33 » Thu Dec 31, 2009 10:22 am
Sean Murray wrote:My machine shop rotated the shell for me :)
Isn't that cheating?
I found a 1.1/4" A/F socket to be the perfect diameter - 60 seconds and the job was done.
Brian Clarke
(1972 Sprint 5 EFI)
bcmc33
PostPost by: GrUmPyBoDgEr » Thu Dec 31, 2009 10:30 am
I have to admit that the cam lobes bothered me regarding a balance issue. Four lobes now ground down. I was surprised how deep the chill went - too hard for turning.[/quote]
It has been done. I did it on may Dad's little 3 1/2" lathe with 1/4 HP Motor with a Centre to support the free end.
It did admittedly make horrible graunching noises & seemed to jump around in the process.
Oh the innocence of youth :roll:
GrUmPyBoDgEr
cron
