Engine Oil
I currently have Miller?s Classic 20w/50 semi-synthetic oil in my car as recommended by Matty, and shall replace it with the same over the winter.
Both my normal road cars specify 5w/30 semi-synthetic oil ? as a matter of pure interest, what affect would it have if I put it in the Twink?
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
bcmc33 - Coveted Fifth Gear
I'm not sure what the effect of the lower viscosity rating would be in terms of lubricating the engine - it might not be a good thing, you'd probably also get more oil passing down the valve stems. Given the normal incontinence of twincam engines I suspect that it would more or less certainly leak more..!
Craig
Craig
Craig Elliott - Third Gear
thinner oil = more prone to leakage especially around the main seals and the valve stems, but also the wick effect through cork gaskets increases. The engines were built for single viscosity mineral oils, so all gaps and tolerances are for that purpose.
Leif
1968 +2 Wedgewood blue
Houston, TX
Houston, TX
- leifanten
Surely not a 'straight' grade! 20/50 multigrade...
The original side valve motor may have used a single grade oil, but not a high revving Twinc.
I have tried 10/40 and it does leak, but so does 20/50! If you use the car in winter, it may be worth a change to 10/40 to save the cold start wear.
Me? I used Millers 20/50 sport in summer, standard Classic 20/50 in winter.
Jeremy
Jeremy
JJDraper - Fourth Gear
frearther wrote:I'd be concerned about the ZDDP problem with modern oils. There are lots of threads on this - just search the archives for ZDDP.
I agree Art, that's why I shall stay with Miller's Classic oil which contains ZDDP.
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
I tried synthetic in the super 7 tc and spun #3 main bearing ----I use 15 40 diesel sump oil now in all the lotus cars ----[2 tc and a Renault and the fv ] with complete success ---recommend it over normal oil now ----ed
Years ago it wa recommended that I use Mobile 1 (there was only one version then) and I have stuck to that. Engine has done about 50k since then and apart from a lower oil pressure (35psi) I have not had any issues..apart from the drips o il on the garage floor and the underneath of the car, but it keeps my chassis rust free
Carl
Carl
pereirac - Fourth Gear
pereirac wrote:I have not had any issues..apart from the drips oil on the garage floor and the underneath of the car, but it keeps my chassis rust freel
My engine comes out tomorrow for a gearbox change, and while it is out I plan to do the Rohan Hodges sump mod and make an attempt at curing the the film of oil that persists around the sump gasket.
But a question comes to mind - with complete sealing of the top and bottom of the cork gasket, will not oil eventually bleed across and still result in a film on the outside?
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
Users browsing this forum: chuckathon and 26 guests
