Reliable garage for engine work London/SE/Kent area
PostPost by: Chickenhawk » Sat Oct 24, 2009 9:39 am
I've got a plus2 with a head gasket that's leaking oil, can anyone recommend a garage in the London/SE/Kent area that's any good to replace it?
I've also had an issue with my rear hubs fouling the lower wishbone bolts. I attributed this to worn outer bushes and changed them which helped and seemed to cure it, but the working clearance is still only 3-4mm between the bolt heads and the inner rim. Is that about right or should there be a small spacer/shim on the hub?
Thanks :lol:
"As a child, Robert Mason dreamed of levitating. As a young man, he dreamed of flying helicopters - and the U.S. Army gave him his chance. - Chickenhawk by Robert Mason"
Chickenhawk
New-tral
PostPost by: rocket » Sat Oct 24, 2009 9:52 am
Hi cant help with garage,wrong area for me.Ithink the bolt to rim clearance on my plus 2 is similar to yours so id say your ok with that.
Ian.
rocket
PostPost by: Chickenhawk » Sat Oct 24, 2009 9:55 am
mmm.....I guess that's 'proper' engineering then. Bit tight for my liking.
Thanks for reply
Chickenhawk
New-tral
PostPost by: Roy Gillett » Sat Oct 24, 2009 1:51 pm
Lakeside Engineering in Woking in Surrey are a good bet for the engine work. Max there knows what he is doing and is honest and trustworthy in my book.
The rim to bolthead clearance you mention sounds about right to me. It is really tight and one of my steel wheels has to go on the front as there is one spot where the rim brushes the bolthead on the rear even though it measures up as round!
Roy
Roy Gillett
