Oil filler cap - fitting wire?
PostPost by: jono » Thu Oct 15, 2009 1:24 pm
I have made a new wire to secure the cap to one of the cam cover studs as there was none before.
Does anyone know how to secure it to the cap? The cap appears to be in 2 sections but I can't seem to see how they are separated :?
Cheers, Jono
PostPost by: john.p.clegg » Thu Oct 15, 2009 5:03 pm
Jono
Someone told me that you just bend the wire back (to put a barb in it?) and then just feed it into the hole...
John :wink:
PostPost by: Frank Howard » Thu Oct 15, 2009 5:24 pm
Jono,
Flip the cap over and look at it. The chrome part of the cap is bent around the inner part in 3 places. You have to carefully unbend the chrome part to release the inner part. You may get away with unbending it in one place only and the inner part should come out. Be careful not to damage the chrome part because as I understand it these caps are practically impossible to find and if you are lucky enough to find one, you'll pay dearly for it. Good luck.
Frank Howard
'71 S4 SE
Minnesota
Frank Howard
PostPost by: Yum-yum » Thu Oct 15, 2009 5:43 pm
It's been twenty years since I fixed mine so its possible I'm remembering this wrong, but is there a hole from the underside of the cap that you could feed a crimped cable through (such as a bicycle shifter cable). Then you would need to attach a tab to the other end for the stud connection end.
Alex
45/8236
Redwood City, CA
Yum-yum
PostPost by: jono » Fri Oct 16, 2009 9:01 am
Thanks guys,
I managed to uncrimp the stainless cap, fit the wire and carefully re crimp. I found the old wire and lead nipple inside!
I used a stainless bike shifter cable with integral nipple and all looks well.
Cheers.
Jono
PostPost by: paddy » Fri Oct 16, 2009 11:08 am
You can get "very rare" NOS bits of wire on Ebay, if the oriiginality of your bike cable bothers you :)
PAddy
1963 Elan S1
paddy
PostPost by: jono » Fri Oct 16, 2009 3:52 pm
Paddy,
Yes, I have spotted those too - you can only laugh!!
Jono
PostPost by: andyelan » Fri Oct 16, 2009 6:53 pm
Hi Everyone
I believe the caps are available new too, I just cant remember where I've seen them (maybe Burtons). What they don't have however is the retaining wire.
Andy
andyelan
PostPost by: john.p.clegg » Sat Oct 17, 2009 8:43 am
Dear All
After reading the posts above,decided to fit the holding wire in my cap.....yes,you can prise the inner out of the outer and a ferrule crimped on the end finishes the job...
John :wink:
P.S. cycle control cable and electrical connector eyelet
PostPost by: neilsjuke » Sat Oct 17, 2009 3:53 pm
Silver solder end of wire with micro torch flame so just fit the hole feed into hole reheat the wire and scrape upwards to form a ridge.
Neil
neilsjuke
PostPost by: Robbie693 » Mon Oct 19, 2009 9:58 am
I'll say - one just went on ebay for ?94.00!
I didn't know they were available new, thanks Andy, listed on Burton's website for ?39.10:
Description: OIL FILLER CAP: LOTUS TWIN CAM & BDA
Other Info: NEW BILLET MACHINED ALLOY CAP
Robbie693
PostPost by: adigra » Wed Oct 21, 2009 12:16 am
I'm quite curious about this Burton cap as I've been seeing it on ebay for a while. It's machined alloy, so am I right in assuming it would be much thicker and therefore difficult to drill and fit a wire to it? It looks great, I must admit, but I wish someone would remake the pressed ones, as original.
Adi
1967 Elan S3 S/E FHC
adigra
PostPost by: paddy » Wed Oct 21, 2009 6:34 am
I have a spare one of those 3-point caps, good condition, if anyone wants one. It has the hole for the wire, but not the wire itself. I'm not after silly ebay money for it, so make me a reasonable offer via PM if you're interested.
Paddy
1963 Elan S1
paddy
PostPost by: paddy » Wed Oct 21, 2009 4:50 pm
paddy wrote:make me a reasonable offer via PM if you're interested.
Now sold.
Paddy
1963 Elan S1
paddy
cron
