Removing old Crackle Paint for the Cam Cover
PostPost by: andyhodg » Mon Sep 28, 2009 12:17 pm
Hi All
Can anyone recommend the best way to remove crackle paint from a TC cam cover. About a third of the paint has already flaked off but the remainder is stuck firm. Will Nitromores work? Or should I just scrape it off using a sharp scraper? I aa intending to repaint with new crackle finish paint.
Any ideas gratefully received.
Andy
andyhodg
PostPost by: miked » Mon Sep 28, 2009 12:24 pm
Yes. does a great job.
Mike :D
Elan S4 Zetec
Suzuki Hustler T250
Suzuki TC120R trailcat
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
miked
PostPost by: Frank Howard » Mon Sep 28, 2009 2:36 pm
Andy,
I used a wire wheel mounted on my 8" bench grinder. To get to the hard places, I used a smaller wire wheel (probaby 3") mounted on my air die grinder.
Frank Howard
'71 S4 SE
Minnesota
Frank Howard
PostPost by: jono » Mon Sep 28, 2009 2:54 pm
Nitromors, pressure washer, job done 8)
...this technique has saved me a fortune in trips to the local blast shop.
PostPost by: dusty » Mon Sep 28, 2009 3:17 pm
jono wrote:Nitromors, pressure washer, job done 8)
I'd second that. I use a brass wire brush to get into the awkward places, wear goggles though as the nitromors can splash if you get vigorous with the brush!
dusty
PostPost by: TeeJay » Mon Sep 28, 2009 3:48 pm
Yes, as the above posts.
I used Nitromors on mine, make sure its the "water washable" type in the green can.
Wash/scrub with water and dry.
I used a stainless steel hand brush in the awkward corners.
You get a pack of 3 hand brushes, (like a large toothbrush) stainless, brass and steel from Wilkos. Last time I got some they were a ?1 per pack and I use them all the time.
Trevor
1968 Elan +2 50/0173
PostPost by: jono » Mon Sep 28, 2009 4:01 pm
Trevor,
Yes, still ?1 from the wonderful Wilko's - exactly what I use, the brass ones work a treat :mrgreen:
....or ?5 from Frosts for exactly the same brush kit :shock:
PostPost by: andyhodg » Mon Sep 28, 2009 10:08 pm
Thanks guys, I used nitromors and wire brush this evening. Nice and easy, job done. Now for the painting.
Thanks again
Andy
andyhodg
Users browsing this forum: No registered users and 51 guests
