Random Misfire
I have a random misfire or hesitation over 4500rpm. It seems to occur, then go away. At first I thought it was due to the coil getting hot, or the coil being too high voltage for the distributor (Pertronix Flamethrower with original Lucas distributor). I checked under the cap and all looks fine and last time it occurred, the engine was at proper operating temp. I also checked fuel pressure and my regulator is set on 2, as others have suggested is a good level. (Stromberg carbs and electric fuel pump) I'm getting ready to just order a new cap, rotor and spark plugs leads as mine are quite old anyway, but it almost seems fuel related, in that once it occurs, it usually doesn't occur again. Almost like clearing its throat, once clear, its good to go. I'm stumped. Any thoughts appreciated.
Dan
PS. I checked the plugs which are a nice light brown.
Dan
Users browsing this forum: No registered users and 50 guests
