Jackshaft bearings renewal
PostPost by: handi_andi » Wed Sep 02, 2009 6:00 pm
Hello all
Anyone got any good tricks for removing and replacing the jackshaft bearings? Particularly ideas for how it can be done without the lotus tool that I don't own.
Andy
handi_andi
PostPost by: andyelan » Wed Sep 02, 2009 6:16 pm
Hi Andy
I havn't done this job so I can't say for sure, but I think you'd be asking for trouble without the special tool or at least somthing similar. The problem is likley to be fitting new bearings without damaging them. Of course I'm lucky as I have a lathe and a press so I'd probably make somthing up myself, however, I can't see any way of replacing these bearings safely without a mandral of some sort.
Andy
andyelan
PostPost by: dusty » Wed Sep 02, 2009 9:55 pm
That's if you can get them, most sources seem to be out of stock at the moment.
dusty
PostPost by: handi_andi » Thu Sep 03, 2009 9:46 am
Luckily for me Paul Matty Sportscars had some in stock when I phone yesterday, I had started to notice a scarcity in the market though. Also noticed that the ones Burton Power sell seem to have a slit in them presumably to add installation? If all else fails I can see a dremmel moment coming on
Andy
handi_andi
PostPost by: rgh0 » Fri Sep 04, 2009 12:44 pm
I always use a suitable socket and a socket extension shaft - no problems
cant remember what size but one is a perfect fit to drive old one out and new ones in
PostPost by: handi_andi » Fri Sep 04, 2009 4:44 pm
Good call mate thanks, just need to take a set of callipers with me to the tool shop :D
Andy
handi_andi
PostPost by: andyelan » Fri Sep 04, 2009 5:03 pm
Hi Andy
For your info, the bearings are 1.7" OD and 1 9/16" ID. Just be sure to push then in square when you're fitting them
Andy
andyelan
PostPost by: curly type 26 » Sat Sep 05, 2009 5:13 pm
And make sure your oil press holes line up or there will be tears shed! & clean all galleries thoroughly pop out all plugs and make sure no crap hiding in there :D Curly
curly type 26
PostPost by: GrUmPyBoDgEr » Sat Sep 05, 2009 6:01 pm
curly type 26 wrote:And make sure your oil press holes line up or there will be tears shed! & clean all galleries thoroughly pop out all plugs and make sure no crap hiding in there :D Curly
Or cut the back end of the Jackshaft off & push the old rear bearing back in with a bit of "Locktite" & ensure that the oil holes don't line up to avoid a leakage.
Result: A bit more oil flow to the parts that could need it & 1 less bearing to cause friction or to worry about.
Beware of the Illuminati
GrUmPyBoDgEr
PostPost by: types26/36 » Sat Sep 05, 2009 6:19 pm
[quote="D.J.Pelly"Or cut the back end of the Jackshaft off & push the old rear bearing back in John[/quote]
.......and dont forget to fit an electric fuel pump.
types26/36
PostPost by: GrUmPyBoDgEr » Sat Sep 05, 2009 7:02 pm
Ooops,
thanks for that Brian.
My Twinks were in race cars. I'd forgotten that the pump excenter was on the back end of the Jackshaft.
John :oops: :oops:
GrUmPyBoDgEr
PostPost by: curly type 26 » Sun Sep 06, 2009 10:14 am
Its the way to go & machine off unwanted loabes, slightly zippier efect, fit fuel pump & inertia switch too, can be used as efective anti-theft (have new pump & fittings if you want one now not using as going FI route) have fun Curly :lol:
curly type 26
PostPost by: handi_andi » Tue Sep 08, 2009 8:24 pm
For reference a Draper 30mm deep impact socket is 1.7" in diameter and has just been used to tap out the old jackshafgt bearings without any damaged in under a minute each
Andy
handi_andi
Users browsing this forum: No registered users and 50 guests
