starter
OK guys for the first time in 25 years of brit cars I have had a starter completely jam the fly wheel----no amount of rocking or glorious English epithets would free it up -[ this should not happen within 400 yards of a school -- church --or hospital ]------had to undo the bolts to free the Bendix ---so the question is ---do i keep the Bendix shaft scrupulously clean with brake cleaner ----use wd 40 -- white grease --or auto trans fluid ---ed
Ah Ed,
The glories of bendix starters. Sorry to hear of your problem.
I keep the bendix shaft clean and use a light oil. This side of the pond it's called 3-in-one. Suppose you guys might call it gun oil.
Hamish.
PS I've just replied to another post in this forum about a new battery. With a little digging around, the bendix solution may be at hand!
Hamish.
Hamish Coutts - Fourth Gear
twincamman wrote: had to undo the bolts to free the Bendix ---so the question is ---do i keep the Bendix shaft scrupulously clean with brake cleaner ----use wd 40 -- white grease --or auto trans fluid ---ed (
Ed,
I only use wd40 or the equivalent on the shaft as I think oil/grease attracts dirt, I also think the problem may not be the "lubrication" of the bendix but you may have a flywheel tooth issue. It has been disussed a few times before but I have found useing a 9 tooth bendix on my S2 (worn f/wheel teeth) gave problems, I changed to 10 tooth and no more probs.
Brian.
OK thanks guys ---Hamish -- here in Canada we are not allowed guns so we call it sewing machine oil ----ed
I personally always use dry graphite flakes, usually sold in a small puffer pack and made to lubricate locks. Its the only product which lubricates without attracting dirt which all greases & oils do over time. Its also rather good for locks!
- storrar54
