Ride height/camber question
PostPost by: GreekS1 » Mon May 25, 2009 4:10 pm
Hi again! Sorry if this has been posted before but Ive searched and I cant seem to find a definitive answer:
my s3 sits too low at the back. The back wheels are too 'opened up' ie a lot odf positie camber. Can anyone tell me the correct camber angle for road use as well as the standard ride height front and rear?
Vassilis
1967 Elan S3 SE FHC
2000 Elise S1 - Sold
Athens - Greece
GreekS1
PostPost by: andyelan » Mon May 25, 2009 5:05 pm
Hi there Vassilis
I believe rear camber should be 0 to 0.5 degrees positive for series 1 and 2 Elans and
0 to 1 degree for series 3 Elans onwards and Plus 2s.
I was always under the impression ride height was 6 inches (to the underside of the chassis closure plate) for Elans and 6.5 inches for Plus 2s. I can't really see why the ride high of the Plus 2 should be greater than that of the Elan other than the fact it's on bigger tyres.
Hope this helps
Andy
andyelan
PostPost by: jkolb » Mon May 25, 2009 11:51 pm
Is the chassis closure plate the flange that the body bolts to on the "backbone"?
Thanx
Jerry
64 26R clone
07 Exige S
jkolb
PostPost by: andyelan » Tue May 26, 2009 3:02 pm
Hi Jerry
"Chassis closing plate" is what it says in the workshop manual but I've never been too sure myself exactly what this means. The description suggest heights should be taken to the centre of the chassis spine ,however, from my measurements its the flanges on which the body mounts which are in line with the front cross member (actually the top of the flanges) so its these positions I use as datums just as you suggest. If you do set the ride height exactly the same at these positions, the chassis and more importantly the rear wishbone pivot axis, will then be parallel to the ground, which I assume is how it's supposed to be.
All the above applies to my '73 Plus 2 but I assume it the same for the Elan
Andy
andyelan
PostPost by: GreekS1 » Wed May 27, 2009 8:04 am
Thank you for your replies!!
I will take the car to have it for allignment soon... I just hope I dont need new rear springs :? ....
Vassilis
1967 Elan S3 SE FHC
Athens - Greece
GreekS1
PostPost by: GreekS1 » Wed May 27, 2009 8:21 am
Just a pic to show how the car sits... It has quite some positive camber in the rear!!
http://s727.photobucket.com/albums/ww27 ... C03506.jpg
1967 Elan S3 SE FHC
Athens - Greece
GreekS1
PostPost by: elj221c » Wed May 27, 2009 9:13 am
Vassilis,
From your photo it would appear you have negative camber as the wheels are closer at the top than at the bottom.
I have to disagree with Andy. From the workshop manual it should be between 0 and 1 degree negative on the back. A little negative is what I like.
Again, from section C (front suspension) the 6" height at the rear is to the bottom of the chassis rail adjacent to the pivots. At the front it should be 6.125".
Roy
'65 S2
Roy
'65 S2
elj221c
PostPost by: andyelan » Wed May 27, 2009 7:07 pm
Hi there
Apologies, Roy's quite right, its 0-1 degree negative at the back. I'd not looked properly given the figures for the front suspension. Sorry about that.
Andy
andyelan
PostPost by: peterako » Wed May 27, 2009 8:23 pm
Hey Vassilli!
My Cam cover's green too (I painted it that way out of patriotic duty :))
Peter
Peters +2 Cam Cover.JPG and
peterako
PostPost by: GreekS1 » Thu May 28, 2009 7:43 am
Looking good peter!! :wink:
1967 Elan S3 SE FHC
Athens - Greece
GreekS1
Users browsing this forum: No registered users and 50 guests
