Broken dipstick
PostPost by: pburgess000 » Tue May 12, 2009 7:40 pm
Yes, it's snapped off flush with the top of the tube, right after an oil and filter change.
Both halves are visible but the worry is that too much fiddling will push them further down into the sump. Of course taking the sump off would fix the problem, but if anyone has found and easier way I'd be delighted to know.
Many thanks,
Peter
1971 S4 DHC
pburgess000
First Gear
First Gear
PostPost by: andyelan » Tue May 12, 2009 7:58 pm
Hi Peter
As a last resort would it be possible to pull out both the dipstick and tube together ? You might damage the tube and have to buy a new one but I think it's only a push fit into the block
Andy
andyelan
PostPost by: tdafforn » Tue May 12, 2009 8:19 pm
big strong magnet
T
1972 +2S130
tdafforn
PostPost by: gjz30075 » Tue May 12, 2009 10:29 pm
+1 on the magnet. Also try a needle nose pliers.
Greg Z
'72 Sprint
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: jkolb » Wed May 13, 2009 1:22 am
If you have access to a doctor, a long nosed hemostat is excellent. These are like rigid tweazers with a lock. Used tool places often have them.
Jerry
64 26R clone
07 Exige S
jkolb
PostPost by: 1964 S1 » Wed May 13, 2009 4:11 am
This whole thing is a put on, right PETER? Both halves are in the hole? How the hell did you or they, do you take your Elan to a Jiffy Lube, break an Elan dipstick? AND, get the end loop crammed in the tube. Come on, if you're going to try and sham us get real, get a life.
1964 S1
PostPost by: steveww » Wed May 13, 2009 8:14 am
The dip stick tube is just a push fit so it would/should be possible to pull out the tube and the stick as one. A new tube will of course be required afterwards but these are available from the likes of QED.
steveww
PostPost by: pburgess000 » Wed May 13, 2009 10:04 am
Thanks for all the tips guys. And no it's not a put on. Removing the dipstick tube seems like a good idea, though from memory (I am at work) it looks welded into place. Not really anything left to grip on for pliers, but anything is worth a go rather than removing the sump! I will keep you updated. Peter
pburgess000
First Gear
First Gear
PostPost by: JJDraper » Wed May 13, 2009 1:23 pm
How about a thin self tapper screwed a little way in between the two halves and pull gently. If the two halves pull out a bit with the screw, screw it in a bit more and repeat the action, until there is enough of the broken stubs to grasp with a pair of pliers. Then gently pull the whole lot out - easy!
Take care not to pull one half out leaving the other to drop down into the sump....
Jeremy
PostPost by: 1964 S1 » Wed May 13, 2009 1:39 pm
I apologize for my insensitivity, I think I finally realize what you mean by both halves are in the tube. I'd tightly clamp some vise grips on the tube at the top and wiggle/yank the whole mess out. "one half" is only a short piece of metal that can easily go into the sump.
Eric
1964 S1
PostPost by: john.p.clegg » Wed May 13, 2009 7:03 pm
Does anyone mind me suggesting pushing the two halves into the sump? I'm sure they will stay there,not get caught up in any whirling machinery, not get "sucked up" into the oil pump and can be retrieved next time the sump is dropped?
Or am I a luddite?
John :wink:
PostPost by: elansprint71 » Wed May 13, 2009 7:20 pm
If you do pull the tube out (which is easy) don't forget to measure how far it sticks out before you remove it. :twisted:
PostPost by: paddy » Wed May 13, 2009 7:23 pm
john.p.clegg wrote:Does anyone mind me suggesting pushing the two halves into the sump?
I suspect they won't go all the way down and fall out of the tube. Isn't the "long" half pretty close to the floor of the sump in its normal position?
Paddy
1963 Elan S1
paddy
PostPost by: 1964 S1 » Thu May 14, 2009 4:53 am
I'm still having a hard time believing this whole conversation. How could one possibly jam dip stick pieces INTO the sump? IF this is all for real, follow elansprint71 and my advice.
And.... I'd still like to know how someone could break an Elan dipstick in half.
1964 S1
PostPost by: john.p.clegg » Thu May 14, 2009 5:57 am
After sleeping on it,yes,the pieces would be too long to push into the sump pan...
Sorry
John :oops:
Next
