Oil Presure sender
My Oil pressure sender unit has failed. The oil pressure dropped suddenly. First I thought it was something serious but I earthed the gauge wire and the gauge moved and I replaced the sender unit with a mechanical gauge and it read 20psi with the starter motor spinning the engine. Phew!
So where can I get the correct replacement sender unit? Mick Miller does not stock them and Matty only stocks 100psi sender units and says the correct ones for our cars and unavailable. There are also loads of 100psi units on ebay. I am at work at the moment and cannot remember whether the full deflection on the pressure gauge is 60 or 80 psi, but obviously if I fit a 100psi sender unit, the gauge will read incorrect.
Any suggestions anyone?
Thanks, David
Thanks, David
- davidj
Sometime ago around 6years my sender failed not to be beaten I cut gently around the metal can and removed it, found that the contacts were dirty cleaned them then soldered the metal can back, been like that eversince.
I had to remake the the wiring connection but that is easy
Better than throwing it away.
JH
JH
+2s130 1971
+2s130 1971
Hawksfield - Fourth Gear
http://www.gaugeguys.com/Smiths/accessories.htm
http://www.nisonger.com/smiths-parts.htm
http://www.powertorque.co.za/caismiths.htm
PTR1812-06 is 60 PSI 1/2" UNF.
PT1811-06 is 60 PSI 1/4" BSP
David
1968 36/7988
David
1968 36/7988
msd1107 - Fourth Gear
Does anyone know the model number for the Smiths 60psi gauge. I think I have found a supplier for the sender unit but the lady on the switch board would not talk to me unless I knew the model number, and I don't fancy pulling mine out of the dash to find some id!
David
David
- davidj
Not sure if it's a help - I've just checked mine and the only number I can find on the case of the gauge is 103...
C
C
Craig Elliott - Third Gear
Golden Gate Lotus Club has senders and gauges (and parts numbers) in their cross reference at http://www.gglotus.org/ggpart/ggpart.htm
Keith
Keith
- kcrossle
I followed JH's advice, but rather than cut the unit, I discovered it is very easy to prize the case apart at the bottom, where the metal is rolled over the base. I then cleaned the contacts, reassembled and it is working again! There is also no obvious damage to the unit.
D
D
- davidj
I don't suppose anyone has measured the resistor in the sender while they had it apart?
John,
Had to take my oil pressure sender apart to clean dirty contacts, oil pressure reading was all over the place. Scary moment. The resistor is a 1/4 watt carbon composition type, +/-20%, the colour code reads 200 ohms (a non-preferred value) but the resistor actually measures 30 ohms on my meter (0.5% accuracy) so must be wired in parallel with the switching heater coil.
I thought about replacing the resistor but it shows no sign of deterioration or overheating so I did a test with the sender unit temporarily reassembled and the oil pressure reading is back to its normal 40psi at 2,000rpm hot, 20psi idling. So I've reassembled the sender properly and left the old resistor in place.
dennis
edited to correct a mis-reading of the resistor colour code value.
dennis
- surveyor
Users browsing this forum: No registered users and 46 guests
