air filter position - engine intake S4
I have an elan S4 and need to install air filter hose and cart etc. I've opted for original type and have parts.
The nose of this car must have been replaced so there's no holes to know the correct position.
Has anyone got a photo or could even take one to send me if your kind showing the posithion in the cone tat is correct, othrwise i will have to guess
thanks
Rupert
thanks
Rupert
- Rupert
My old body had at least 50 extra holes in the body and was basically wasted beyond repair (sawn out wheel arches, etc) - so I bought a new body from Tony Thompson. So I had no holes to guide me either. Just position filter as far to the left (looking at car from the front) as you can, without hitting the 4" flexible ductwork or the headlight pods (move them thru their arc of travel). Then move backward toward the steering rack and you'll see you can only locate it within about a 2" circle - as I recall. My next project will be to block off all areas around the radiator so air HAS to go thru it - not around it. Good luck
Paul Zimmerman
65 S2
Paul Zimmerman
65 S2
- brassringfarm
Rupert wrote:I
Rupert
Rupert,
P.M. me with your email, I've got a couple of pics that may help.
My '69 S4 FHC SE had the airfilter in what I think was the original position, 45? to vertical and plumb in the middle of the car, right across the radiator air-flow, so as the car was over-heating I moved it to the far right of the car, exactly as per "brassrngfm" 's answer, and kept it in a horizontal plane, the twin tubes pointing at the grill. I also fitted the blanking panel (from Sprints I believe) over the steering column, the foam on the bonnet over the radiator, and drilled the two holes in the left-hand inner wing (as per the Factory Workshop manual.....). Together these have cured the overheating, even here in SW France. I think each step only did a little bit, but together it's enough to make a real improvement. Hope this helps, Tony.
1969 Elan FHC S4 SE
- tonycharente
Users browsing this forum: pdenton26 and 38 guests
