Compression test
Dear All
I carried out a compression test on my twin cam last night and got the following results:
1. 165/170
2. 155/160
3. 165/170
4. 165/170
The results are slightly vague as my tester is not very accurate. I didn't have the chance to put oil down the bores so I'm not sure if it's top or bottom end that's caused the drop on chamber 2.
I'm only using the car for some fairly light occasional track day use, so I'm not looking for the last word in performance. My question is - would any of you be concerned about the result for chamber 2?
I don't have the facilities to pull the head or carry out any major work myself, so if it won't make that much difference I'd just like to leave things as they are.
Tom.
1. 165/170
2. 155/160
3. 165/170
4. 165/170
Tom.
- birdthom
Tom,
The manual says to expect 160 or over. Looks like your engine passes, just, on no 2. By all means try a little oil down the bores but only a little. Too much may give you a falsely high reading.
I had a similar post a few weeks ago and someone suggested connecting an airline to the suspect cylinder and listening to where the air leaked from.
Might help decide if it's an engine out job or a head removal to do the valves.
Hamish.
Hamish.
Hamish Coutts - Fourth Gear
birdthom wrote: My question is - would any of you be concerned about the result for chamber 2? Tom.
It wouldn't worry me, if there is a problem it will get worse so just keep an eye on it, if it has to be done at a later stage then "so be it" but as they say "dont fix it if it aint broken"
