Brise Starter
PostPost by: Emma-Knight » Mon Jan 26, 2009 5:17 pm
Just took the opportunity to take a picture from my new Brise starter - not fitted yet. The ringgear on my car is a bevelled on both sides type, the rear wards bevelling grinded somewhat by the Lucas 9 teeth starter.
The Bendix was clean and fast, but cranking speed too slow. It sacrificed itself to save most of the ringgear. The top mounting ear of the Lucas starter was cracked. As pound is low for the Euro I took the chance...
And yes, the Brise is preengaged and gear reduced - all integrated in this nice, almost original shape housing.
I will report how it fits...
PS: I fitted a bulb fuelpump in the boot and just a few pumps and you can feel the carbs being filled and needle valves closing.
Anna
Starter bracket cracked.jpg and
Bendix was still working.jpg and
Brise Starter.jpg and
1965 S2
Emma-Knight
PostPost by: leojenbo » Mon Jan 26, 2009 7:49 pm
I also expect to receive a Brise starter for my Elan Sprint 1972. It was send from Demon Tweek last Friday. 195? + P&P + VAT.
My Elan has been a poor starter for a long time :cry: and the distributor was replaced in the autoumn with a new electronic system looking just as the original. It comes from Tony Thompson, and it really works fine.
I hope the replacement of the LUCAS interia makes the car start perfect! :lol:
/leo
Lotus Elan Sprint FHC 1971
Lotus Seven S2 pre-XF 1961
leojenbo
First Gear
First Gear
PostPost by: elans3 » Mon Jan 26, 2009 10:44 pm
Don't worry guys, I've used these for a long time now with absolutely no trouble.
Great starter speed, half the weight, and no reliability problems.
Can't ask for more !
elans3
elans3
PostPost by: bcmc33 » Tue Jan 27, 2009 12:04 am
The geared starter is so much better than the original fit.
The Brise seems very expensive - I had mine from: www.lukemotorsport.co.uk
He supplies either 9 or 10 tooth pinion types depending on your preference.
I bought a new alternator at the same time - lowest cost I've ever seen.
Brian Clarke
(1972 Sprint 5 EFI)
bcmc33
PostPost by: Bill » Tue Jan 27, 2009 1:54 am
A member of the british Columbia Lotus Club designed and did a production run of 20 adaptors for Nisson gear driven starters about 20 years ago, I laid hands on one about 10 years afo. I can tell all that after 30 plus years of changing out 3 starters and 10 bendix gears I committed to non origionality and now go every time. No more syuck in a parking lot or - worse yet - getting a push start off our ferry from our rock (Vancouver Island) to that place called North America[Canada Hey].
ONLY way to go!
Bill 26/0538
Bill
PostPost by: freddy22112211 » Tue Jan 27, 2009 7:12 pm
Hi Anna,
Where did you get the bulb fuel pump from?
And a picture of the fitting would be very nice!
Gordon
freddy22112211
PostPost by: peterako » Tue Jan 27, 2009 8:07 pm
freddy22112211 wrote:Hi Anna,
Gordon
Yes!
This sounds interesting...and useful :)
Peter
peterako
PostPost by: peterako » Tue Jan 27, 2009 8:14 pm
bcmc33 wrote:The geared starter is so much better than the original fit.
The Luke Motor Sport one looks very similar to the one from RatSport.
http://www.triumphshop.co.uk/ratsport/o ... Torque.htm
Peter
peterako
PostPost by: Emma-Knight » Wed Jan 28, 2009 4:33 pm
Just from an ordinary boat supply shop - 5/16 tube dia, about 8mm
"Kraftstoffleitung" in german... :wink:
The fit is just a test setup and would profit from reworking :roll:
I bought a 10mm fuel line pump by accident and it was a bit hard to fit to the 8 mm rubber tubes.
Apart from this, total costs for doing so is 10 Euro.
Anna
Fuel bulb pump1.jpg and
1965 S2
Emma-Knight
PostPost by: freddy22112211 » Wed Jan 28, 2009 5:26 pm
Great, thanks, Anna. Good idea!
Gordon
1972 LHD Sprint 5 Cabriolet - sold!
freddy22112211
PostPost by: Jolly Jumper » Fri Feb 27, 2009 1:51 pm
Anna,
where did you buy the Brise Starter? I am in Hamburg and I think need one too.
And how does the Brise work? Easy fit?
Jolly Jumper
PostPost by: Emma-Knight » Fri Feb 27, 2009 4:09 pm
direct at brise (google brise and starter) and tell them its for a Lotus Elan TC with two ear mounting flange.
Anna
has not fitted it yet... but looks straight forward as the starter is very slim
just a bit longer than the Lucas
1965 S2
Emma-Knight
PostPost by: alaric » Sat Feb 28, 2009 2:09 am
I have one fitted but don't think it's pre-engaged. See previous threads on this. I bought it from Matty's as a pre-engaged unit but was advised otherwise after I'd fitted it. It works really nicely though, and I'm using it with an original ring gear as other people are - doesn't seem to matter.
Sean.
alaric
PostPost by: mark030358 » Sat Feb 28, 2009 4:36 pm
Are brise starters pre engaged?? or do you retain the origional solenoid??
PostPost by: john.p.clegg » Sun Mar 01, 2009 6:46 am
I believe the brise is pre-engaged,it has the axial solenoid built into the end,so looks more like standard Lucas
John :wink:
Next
