Have I 'fried' my Lucas Electronic Ignition ?
PostPost by: BRMLotusElan » Fri Jan 23, 2009 9:39 am
I connected the battery up wrongly (incorrect polarity) to my Lucas electronic ignition....
Amplifier = AB14, coil = DLB198 & dizzy = 43DM4 (race type)
It will no longer start - what have I damaged ?
Dennis
www.brmlotuselan.com
BRMLotusElan
New-tral
PostPost by: ecamiel » Fri Jan 23, 2009 9:26 pm
Do you have a spark?
How much amperage is it drawing? 6 amps is blown.
Now here's the good news. Open it up and the inside is a cheep Delco part with part number on it.
Eric
64 S1
ecamiel
PostPost by: BRMLotusElan » Sat Jan 24, 2009 9:43 am
Eric
Thanks for the info.There is no spark.
How do I check the amps? (Keep it simple!)
I assume you are refering to the AB14 "black box" when you say "open it up" (I know zero about electronic stuff!). Inside is a capacitor, a diode, possibly a tacho sensor unit and what may be the amplifier with leads to the dizzy.There is a code--(GM 613 3B18) on this unit is that the part you mean ?
Many thanks
Dennis
BRMLotusElan
New-tral
PostPost by: Elanintheforest » Sat Jan 24, 2009 12:04 pm
Dennis
Is your Lucas ignition the old Opus system by any chance? Does it look like the one in the picture? This was fitted to my Plus 2 in 1971 along with the BDA, and I'm hunting down some spares for it. They were used by Ford on the rally RS1600 Escorts, and were meant to be a bit unreliable...but mine's been fine for 38 years!
Sorry to hijack your thread, but I don't often see Lucas ignition systems being mentioned, and just wanted to see if you could confirm what my system is to refine my hunt...and maybe yours!
Opus1.jpg and
PostPost by: neilsjuke » Sat Jan 24, 2009 5:26 pm
If the diode is in the supply lead then you should not have damaged the unit with the incorrect polarity of the battary .if you have a rev limiter you may have upset that .
Neil
neilsjuke
PostPost by: BRMLotusElan » Tue Feb 03, 2009 3:32 pm
Thanks for the helpful replies, especially Jeff. The problem may now be sorted.
Dennis
BRMLotusElan
New-tral
