Crankshaft Pulley
PostPost by: bcmc33 » Tue Nov 25, 2008 6:37 pm
What is the relationship between the crankshaft pulley keyway to TDC and the pulley TDC notch?
Brian Clarke
(1972 Sprint 5 EFI)
bcmc33
PostPost by: mikealdren » Wed Nov 26, 2008 7:54 am
Brian,
I don't think there is a fixed relationship, the crank is machined and assembled and then the notch is cut to mark TDC for that individual part. If you fit a new pulley, it will need remarking.
I suspect that, with modern machining, parts can be marked on manufacture now.
regards
mikealdren
PostPost by: denicholls2 » Wed Dec 03, 2008 12:28 am
mikealdren wrote:Brian,
Given that these are Ford parts, and Henry Ford was the pioneer of interchangeable parts in automobile manufacturing, I would be very surprised indeed if this were true. :shock: Establishing a fixed relationship between TDC on the crank and the pulley marks that is constant across parts is not rocket science, and avoids having your timing in some bizarre place when you replace the pulley for whatever reason.
Can this really be true? If so, good to know when building an engine from bits.
denicholls2
PostPost by: bcmc33 » Wed Dec 03, 2008 12:49 am
Common sense tells us that there is clearly a definite relationship - I just don't know what it is and thought someone on the forum would know.
I have just removed the radiator tonight and will remove the pulley tomorrow and do some measurements so that I can mark the toothed billet pulley I intend to use for distributerless ignition.
Brian Clarke
(1972 Sprint 5 EFI)
bcmc33
PostPost by: bcmc33 » Thu Dec 04, 2008 12:21 am
FWIW the crankshaft key is at 12 o'clock on TDC. Quite predictable, I guess.
The TDC notch on the pulley is 50 degrees from the from the 12 0'clock key position.
Brian Clarke
(1972 Sprint 5 EFI)
bcmc33
PostPost by: john.p.clegg » Thu Dec 04, 2008 7:03 am
So the TDC mark on the frontplate is actually 50 B.T.D.C....(just to complicate things)
John :wink:
PostPost by: billwill » Mon Dec 08, 2008 1:47 am
john.p.clegg wrote:So the TDC mark on the frontplate is actually 50 B.T.D.C....(just to complicate things)
John :wink:
But but.... the markings on the front plate are also displaced the same amount...
So they cancel each other out...
8) :lol: 8)
Mind you I reckon it possibly would be easier to see the markings if they were in the centre, between the crank and the water pump.
PostPost by: Galwaylotus » Tue Dec 09, 2008 8:39 am
John :wink:
Isn't that ATDC? Looking at the engine from the front that's just before 2 o'clock!
'67 S3 SE FHC
Galwaylotus
