Popping on overrun
PostPost by: mark030358 » Sun Nov 16, 2008 8:48 am
Just a quick question..
When hot my sprint sometimes "pops" on the overrun, what is the cause of this? It does not do it when cold...
.... and whats the fix??
PostPost by: MintSprint » Sun Nov 16, 2008 3:26 pm
Usually, it's down to an air leak in the exhaust manifold somewhere (either a crack, or a leak at the Y-piece where the branches of the manifold join). Air is drawn in and unburnt fuel explodes in the exhaust, causing the popping.
Less likely, but possible, is a burnt valve causing the same symptoms.
Check for leaks, and if you can't find anything, do a compression check for the valves.
Ignition timing can also have an influence, so it may be worth getting that checked, too.
MintSprint
PostPost by: john.p.clegg » Sun Nov 16, 2008 4:14 pm
A weak mixture will do it,not igniting in the cylinder but burning in the exhaust...
John :wink:
PostPost by: steveww » Sun Nov 16, 2008 10:49 pm
Mine had a bit of popping on the over run, advancing the ignition a tad cured it.
steveww
PostPost by: mark030358 » Mon Nov 17, 2008 1:57 am
I think I'll go for the exhaust sucking in air... as from memory there was a small amount of carbon around the Y piece.
many thanks
