Inlet runner length
PostPost by: john.p.clegg » Thu Oct 23, 2008 12:55 pm
Dear All
If anyone has their head off at the moment could they do me a favour and measure the inlet runner length (valve to trumpet) so's I can do a few calculations........(harmonics/tuned lengths)
Many thanks
PostPost by: Frank Howard » Thu Oct 23, 2008 4:20 pm
John,
I've got an extra Stromberg head that I could pull out and measure, or are you looking for Weber?
Frank Howard
'71 S4 SE
Minnesota
Frank Howard
PostPost by: types26/36 » Thu Oct 23, 2008 4:35 pm
john.p.clegg wrote: measure the inlet runner length (valve to trumpet)
Not sure what you mean by "valve to trumpet" ......do you want the distence from valve stem to flange (carb mounting face) on a Weber head?
types26/36
PostPost by: john.p.clegg » Thu Oct 23, 2008 5:13 pm
Sorry,weber head please,distance from valve head to the air inlet ie.the curved piece of the "trumpet" in the airbox
John :wink:
PostPost by: TeeJay » Thu Oct 23, 2008 10:40 pm
John,
I have taken some measurements which are on the attached photo's.
Not to sure re the "valve head", but hopefully the various sizes will help.
If they do not, please contact me and I can take additional ones.
The sizes taken are with a steel rule, but if you what micrometer measurements, then let me know.
Weber Carb + Trumpet - Length.jpg and
Spacer + O Rings Measurement.jpg and
Cylinder Head Measurement.jpg and
Cylinder H Measurements.jpg and
Trevor
1968 Elan +2 50/0173
PostPost by: john.p.clegg » Fri Oct 24, 2008 5:42 am
Trevor
Many thanks.....makes a total of 13.75" which gives a tuned RPM of approx 6000,so my reduction down to 12" approx will take the tuned length up to nearer 7000 rpm....and I suppose harmonics of that....3500 would be good for cruising I suppose...
John :wink:
