Headlamp vacuum loss
Hi there,
I've changed the headlamp vacuum pipes and checked the unions and non return valve on my 1973 +2 but the lamps still pop up minutes after switching off. All that's left is the vacuum pod and the solenoid. Is there a way of telling which is at fault without buying both items new and has anyone managed to change the seal in their solenoid? (mine is a replacement). Grateful for any help,
Simon
Simon
Si_130/5 - Second Gear
Hi Si
Have you tried clipping the tube that leads from the pod (with the headlights down)?
Berni
Berni
berni29 - Fourth Gear
Simon,
There's a write-up about the headlight vac system on the Golden Gate Lotus Club site. http://www.gglotus.org/ggtech/ggtech.htm
Click on "Elan/+2" and look for the article on the Headlamp System.
Kiyoshi
Kiyoshi
khamai - Third Gear
