Camshaft timing ???
PostPost by: Petter Hval » Sun Sep 21, 2008 11:42 pm
I have just found some notes regarding the canshaft timing onmy S4 big valve head made after an engine restoration 3 years ago,and wonder if I should retime the camshafts?
The camshafts are reground to TT 36 spec. and the seat to seat valve lift are 9,68 mm (inlet), valve clearances 0,15/0,25 mm,timing figures 35/85 - 79/41 dgr. and inlet timing @ full lift 115 dgr. The engine havea flat spot from 2400 - 3100 rpm. brobably an carb. issue ?? I`m planing to get some adjustable verniers for the cams, and open for any suggestion how to set the timing.
Petter
0
Petter Hval
PostPost by: ppnelan » Mon Sep 22, 2008 8:28 am
Petter Hval wrote:...any suggestion how to set the timing.
Very carefully... :wink:
Getting the timing right on an engine with a 'peaky' camshaft is critical. Get it spot on and it will purrrrr; get it wrong and it will probably still run but will be a dog... See Miles Wilkins' Twin Cam Engine book for details of how to do it.
:arrow: Matthew
ppnelan
PostPost by: dlbarnes1 » Tue Sep 23, 2008 3:53 am
Top lobe center (full lift) for the exhaust timing works out to 109 degrees BTC.
Dave 72 Sprint DHC
dlbarnes1
PostPost by: Dag-Henning » Tue Sep 23, 2008 12:43 pm
Petter, - the flatspot is most certainly a carb issue. If I get you right ; - yor engine has been running on these cams for the last three years, and you want to check that they are timed correctly ? If so, check that the inlet cam has max lift at 115 degrees, and the ex-cam at 109. That's what your figures says. These are not what I would call "very hot cams" , so one or two degr. out, would probably not make a very big difference .....
Dag
Dag-Henning
Users browsing this forum: No registered users and 50 guests
