Oil filler cap quick fix
PostPost by: robertverhey » Fri Sep 19, 2008 12:30 pm
Hi my oil filler cap has just decided to gush oil everywhere. The rubber sealing ring is hard and brittle, have bent the tabs up, turned the pins in the cam cover around around put some silastic either side of seal but still leaking.
Will order replacement seal from UK (unless local Oz owners can point me somewhere local).....but just wondering, has anyone come up with a quick fix (or even a permanent fix) non-lotus part solution....?
Robert
robertverhey
PostPost by: pamitchell » Fri Sep 19, 2008 1:17 pm
Robert
I replaced my oil cap with a screw on cap from JAE in the USA. $35 USD.
It's polished aluminum and has sealing ring under the cap. You have to cleanly remove the pins on the rocker cover and it is a press fit. No leaks
Phil
Phil
1968 S4/SE FHC 36-7936
pamitchell
PostPost by: ppnelan » Fri Sep 19, 2008 4:29 pm
Some people have made metal shields that fit inside the cam box (I believe) to stop the spray off the cams into the cap. I think of it as part of the original 'chassis lubrication system'... :lol:
:arrow: Matthew
ppnelan
PostPost by: elancoupe » Fri Sep 19, 2008 4:31 pm
pamitchell wrote:Robert
Phil
+1
One of the best mods I have made.
elancoupe
PostPost by: pamitchell » Fri Sep 19, 2008 5:31 pm
Dave Bean sells the oil shield that fits on the cam bearing studs.
It helped reduce oil loss.
Phli
Phil
pamitchell
PostPost by: stugilmour » Sat Sep 20, 2008 3:38 pm
Here is a link to a modification made by the Elan Factory on your side of the world. Have not used, not associated, etc. If the specific link does not work, it can be found under "product datasheets".
Stu
http://www.elanfactory.com.au/business_profile.htm
http://www.elanfactory.com.au/pdf/produ ... %20cap.pdf
Stu
1969 Plus 2 Federal LHD
Users browsing this forum: No registered users and 56 guests
