Stripped thread
PostPost by: Robbie693 » Thu Jul 24, 2008 8:25 am
The thread for one of my thermostat housing bolts has stripped. I'm wondering if the bolt was long enough as it only seems to engage in the first 3 or 4 turns of the thread.
I need to get the car mobile so I take it to get a helicoil inserted and was hoping I could put in a longer bolt.
Can anyone tell me the correct size of the bolt please, diameter and length, so I can tell if mine are too short?
Robbie
Robbie693
PostPost by: garyeanderson » Thu Jul 24, 2008 8:59 am
robbie
The parts manual lists it as hex bolt 5/16" diameter x 15/16 long UNC
This is a bit of odd size but its in the manual. You ought to buy a parts manual, it really saves you time, money, and agrevation, I bought one 20 years ago and brought it to work early one morning and copied the whole thing. The next week returned it to Don at Tingles Lotus center, Don knew it was coming back and sold it to me that way as then he didn't have to look up al of those part numbers for me... :)
Gary
garyeanderson
PostPost by: steveww » Thu Jul 24, 2008 8:59 am
It is easy enough to fit a helicoil or similar yourself. If you are in the UK Namrick sell the coil kits.
steveww
PostPost by: ppnelan » Thu Jul 24, 2008 9:02 am
The Parts List says they are XUCS 0515 = Hex UNC Screw 5/16" x 15/16" long. :o
[Edited] Ooops! Got there too late... :wink:
:arrow: Matthew
ppnelan
PostPost by: garyeanderson » Thu Jul 24, 2008 9:16 am
ppnelan wrote:The Parts List says they are XUCS 0515 = Hex UNC Screw 5/16" x 15/16" long. :o
:arrow: Matthew
There are quite a few odd ball bolts on the Elan that were used because of the special nature of somethings being modified versions of other manufactuired parts. No one is going to stock a 15/16 long bolt. Even here in the U.S where we still use inches and feet. The best you can get at most supply houses are 7/8" or 1 inch, above an inch it goes to 1 1/4". Its not surprising that someone would use the wrong size.
garyeanderson
PostPost by: Robbie693 » Thu Jul 24, 2008 9:25 am
Thanks for the speedy replies guys,
Looks like mine is definitely too short - it's about 3/4".
I'll look at Namrick's site.
And I'll buy a parts manual - probably cheaper than copying one nowadays!
Robbie
Robbie693
PostPost by: garyeanderson » Thu Jul 24, 2008 10:24 am
Robbie693 wrote:Thanks for the speedy replies guys,
Robbie
I was on the clock (on the fiddle?) and got paid overtime for doing it,
pretty sleazy, oh well. Saved me a lot in the end. Well, maybe not, I ended up spending all of my money buying Elans for the next 15 years.
Gary
garyeanderson
PostPost by: Robbie693 » Thu Jul 24, 2008 11:14 am
Nice one.
We need all the help we can get :lol:
Robbie693
PostPost by: cliveyboy » Thu Jul 24, 2008 4:24 pm
Robbie
I have a spare one you can have.
I machined a longer bolt down.
Its unplated but should get you out of trouble.
Clive
1972 Elan Sprint FHC
cliveyboy
PostPost by: john.p.clegg » Thu Jul 24, 2008 8:09 pm
Robbie
Don't bother with bolts,fit an exhaust stud,that way you will only be removing the nuts (as in exhaust) I don't know why Colin fitted studs to the exhaust but not the thermostat housing?
John :wink:
PostPost by: Robbie693 » Fri Jul 25, 2008 8:01 am
hmm, that's not a bad idea.
Thanks John
Robbie693
PostPost by: garyeanderson » Fri Jul 25, 2008 9:36 am
john.p.clegg wrote:Robbie
John :wink:
Probable because 2 studs, nuts, flat washers and lock washers cost more than 2 bolts, flat washer and lock washers.
funny how some people recomend the bolts for the exhaust and studs for the therostat housing :)
Gary
garyeanderson
PostPost by: rgh0 » Fri Jul 25, 2008 11:29 am
funny - I use socket head cap screws in both :D
PostPost by: CBUEB1771 » Fri Jul 25, 2008 12:49 pm
I use studs in both locations. I prefer to put the majority of service cycles on the stud and nut, not the precious soft ally of the head. :lol:
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
CBUEB1771
Users browsing this forum: No registered users and 51 guests
