Valve Guides
They look like Bronze guides I have seen but no guarrantees if from an unknown source.
I dont believe unlead has anything to do with guides. The newer bronze guides have better wear characteristics than the original cast iron guides but unleaded versus leaded has no impact on guide wear.
I agree with Rohan but let me add, the bronze guides are a much better conductor of heat from the valve stem, helping keep the valves a little cooler.
The issue with unleaded fuel is the valve seats. They should be hardened to protect them from recession.
Bill
Bill
- bill308
These do look correct; I have just completed an engine rebuild and replacement of guides and seats, and have recently sold an excess set of guides. Measurements will confirm.
Greg
Greg
elangtv2000 - Third Gear
Hi Jon,
Who is going to replace your valve guides ? Are the seats being replaced as well ?
Lotus heads use alloy steel seats and valves, unleaded is not normally a problem, as it would be with cast iron heads and directly machined valve seats.
I would recommend using a Lotus specialist such as QED for this work.
Sean Murray
Sean Murray
Foxie - Coveted Fifth Gear
Sean Murray wrote:Hi Jon,
Sean Murray
Sean,
I don't know yet, I had thought about doing it myself (guides and seats)!
Unfortunately QED don't do this work anymore they are now purely a parts supplier.
Do you know of any other specialists?
Jon
dusty - Third Gear
Jon,
I'm surprised to hear QED are no longer doing this, the did an excellent (if slightly expensive) job on my Twincam head, replaced all valve seats, guides, cam follower sleeves, porting, machining deeper spring wells for high lift valves etc.
Burton's specialise in Ford/TCs components, I don't know if they do machine work, but it's worth a call.
Try Hi Precision in Tullow-: 059 915 1444
or Howard Engineering in Glasnevin 01 8827555
Both do excellent hi tech machine work, and very reasonable rates.
Howard Engineering had to be prodded a bit to get my crankshaft done in time !
Sean
Sean
Burton do do work on engines (although my guess is that they farm it out).
Otherwise there is Wilcox.
http://www.wilcoxengines.demon.co.uk/xflow.htm
tdafforn - Coveted Fifth Gear
